75
OxygenOS Open Beta 16 for the OnePlus 7 Pro and 7
What do u think?
  1. On purpose
    1 vote(s)
    100.0%
  2. This is a bug
    0 vote(s)
    0.0%
  3. IDK just want check answers
    0 vote(s)
    0.0%
  1. karanmalviya
    Eclair Aug 5, 2020
    karanmalviya , via OnePlus 7 , Aug 5, 2020 :
    Good interaction with you. Got to learn new things from you[e]1f44d[/e]
    bagpiper likes this.
  2. bagpiper
    Ice Cream Sandwich Aug 5, 2020
  3. SVM911
    Gingerbread Aug 5, 2020
  4. c3drik67
    Honeycomb Aug 5, 2020
    SVM911 likes this.
  5. SVM911
  6. raghava sai
    Cupcake Aug 5, 2020
  7. vriesdejoop
  8. raghava sai
    Cupcake Aug 5, 2020
  9. vriesdejoop
    vriesdejoop , via OnePlus 7 Pro , Aug 5, 2020 :
    No, but as beta has a monthly update it is WHITIN 4 weeks, but can also be tomorrow... Who knows..... Not anyone here in a user group! So not very useful to ask.
  10. c3drik67
    c3drik67 , Aug 5, 2020 :
    If you download rollback package it will work. Your phone after that is on android pie, you Can upgrade to android 10 after. But your phone is completly wipe , make a backup.
  11. c3drik67
    No this beta build go out since 11/12 july. 4 week approximatly after this date.
  12. akks
    KitKat Aug 5, 2020
    akks , Aug 5, 2020 :
    No need to roll back to pie or anything. To move to stable from beta 16, simply download 10.3.4 zip file and flash it, like you moved to beta. But data will be wiped though.
    10.3.4 is newer build as compared to beta 16. Won't be possible to move to 10.3.4 once you update to beta 17 when it is released
  13. c3drik67
    It’s possible yes, my phone was on beta since beta 1 i never go back to stable because for me beta have no important bug. I have always read for going back to beta you have to flash rollback. The subtility of newer stable build is interestly. Just cross finger , because some stable build release after beta build don’t work for going back to stable. I have read some issue with that.
    Akshay_Sindhu likes this.
  14. akks
    KitKat Aug 5, 2020
    No issues to move to newer stable builds, I've done many times. Now also I moved from beta 16 to 10.3.4 directly. Not that beta 16 had any issues for me, but one of my mics has some serious issue. Wanted to double confirm if it's hardware issue itself.
  15. Franzie3
    Froyo Aug 5, 2020
  16. Artemus.
    Nougat Aug 5, 2020
    Artemus. , Aug 5, 2020 :
    Hiiiiighly unlikely. Android 11 isn't gonna be out for a few months from now.
  17. buntysidhu
    Cupcake Aug 6, 2020
    buntysidhu , via OnePlus 7 Pro , Aug 6, 2020 :
    It works fine, now I have one plus pro with stable OS. Thanks
  18. rohitisricky
    Donut Aug 6, 2020
    rohitisricky , via OnePlus 7 Pro , Aug 6, 2020 :
    Will it wipe the data from the phone?
  19. Artemus.
    Nougat Aug 6, 2020
    Artemus. , Aug 6, 2020 :
    If it's newer, no. But making a backup just to be on the safe side is recommended.
  20. shikhan_sarkar
    Gingerbread Aug 6, 2020
    shikhan_sarkar , Aug 6, 2020 :
    I am in stable version of the oxygen os 10.3.4. and I want to join open beta. I have downloaded the beta 16 full Rom but, I'm unable to install it via local upgrade. What should I do?
