75
OxygenOS Open Beta 16 for the OnePlus 7 Pro and 7
What do u think?
  1. On purpose
    1 vote(s)
    100.0%
  2. This is a bug
    0 vote(s)
    0.0%
  3. IDK just want check answers
    0 vote(s)
    0.0%
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jul 11, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 11, 2020 :
    I always prefer beta channel... Almost feel kind of lost and sad without it 😋
    I was on open beta since beta 1 (even DP5) until beta 14 when I had to turn on my 7 Pro. I never wanted to change to stable and never used it since open beta came. But it may not fit everybody. It can give some more trouble than fun. If fun happens to be to replicate issues and reporting them, finding walkarounds and solutions... Then you might even enjoy beta even when it is extra troublesome. Even if all the extra features is fun it can also be a bit troublesome sometimes... Like a surprising lockout and need of wiping the whole phone after an update (rare though... Hopefully).
    If stability is you main concern stable is your prefered option. It SHOULD in most cases be the most stable firmware.
    Anishsha and Deactivated User like this.
  2. V1589424193359
    Cupcake Jul 11, 2020
  3. laikexpert
    Honeycomb Jul 11, 2020
    laikexpert , Jul 11, 2020 :
    Some comments have happened on the phone and very difficult comments have made me sad
    P.S.
    Translated from Arabic
    by Google Translate.
    V1589424193359 likes this.
  4. V1589424193359
  5. V1589424193359
  6. Python_Dev
    Gingerbread Jul 12, 2020
    Python_Dev , via OnePlus 7 , Jul 12, 2020 :
    Hello Abdul B,
    Currently I update open beta 16 one Minor issue for the software .
    Note : Home Screen Volte shadow logo issue after I installed the update that one is coming on my screen top this one irritation for me. So please fix the bugs immediately. I waiting for your next patch update. I attached the screenshot Photo for your reference.
  7. Deactivated User
    Jul 12, 2020
  8. Zeus89
    Eclair Jul 12, 2020
    Zeus89 , via OnePlus 7 Pro , Jul 12, 2020 :
    The problem waa that it couldn't be pressed. I did factory reset and everything is fine now
  9. HZ_ND
  10. HZ_ND likes this.
  11. HZ_ND
    HZ_ND , via OnePlus 7 Pro , Jul 12, 2020 :
    Yup.. I've done that. Very bad standby time. The worst since beta 5.
  12. Bhavesh Bhoir
    Eclair Jul 12, 2020
  13. bayy27
    Eclair Jul 12, 2020
    bayy27 , via OnePlus 7 Pro , Jul 12, 2020 :
    Same issue here [e]1f62d[/e]
    Amarjit Baliyarsingh likes this.
  14. olxlo
    Donut Jul 12, 2020
  15. Dinuhunt
    Cupcake Jul 12, 2020
  16. akks
    KitKat Jul 12, 2020
    akks , Jul 12, 2020 :
    Is it because you have poor network coverage for either of your sims?
    I don't have that much standby drain in my 7pro
    RishinP likes this.
  17. HZ_ND
    Dinuhunt
    Want to Move to open beta version from official ROM.. Suggest me pros ans cons of doing this .. Is ot ok to use open beta version over official ROM. PLS SUGGEST.​
    Just do it. Try open beta.. U will like it.. Just keep in mind there are some few bugs here an there.. If you don't mind then can update to ob16.. So far so good no bugs just the battery drain during phone idle is heavy.
    Dinuhunt likes this.
  18. HZ_ND
    I don't think so.. This was the fst time it's been like this. Previously was in stable and open beta never had a issue. The standby time usually drains around 1 percent. But after the update I can see a major drop. No wifi or any other connection in the background. My line is is perfect and no major issue as I'll get constant 4g+ in my area.
  19. HZ_ND
    Do you have any suggestion for me to recalibrate.. I've done full wipe.. But the issues are the same.
