345
OxygenOS Open Beta 17 for the OnePlus 5 and Open Beta 15 for OnePlus 5T
  1. Sérgio Morais
    Cupcake Aug 31, 2018
    Vladut123 likes this.
  2. Mohammed Rishab PM
    Froyo Aug 31, 2018
    Vladut123 and Moses_Camelo30 like this.
  3. G_Ritashree_Das_CXEW
  4. GopalB.
    Nougat Aug 31, 2018
    GopalB. , Aug 31, 2018 :
    What update???
    Are you a beta user???
    Vladut123 and Dresa91 like this.
  5. Horsault
    Nougat Moderator Aug 31, 2018
    Horsault , Aug 31, 2018 :
    As for any system update on any system, it's always a good idea to keep an up-to-date backup of your important data before attempting any potentially hazardous command.
  6. govind80
    Eclair Aug 31, 2018
    govind80 , Aug 31, 2018 :
    Yes, the apps are crashing on its own
  7. I_am_Batman
    KitKat Aug 31, 2018
    I_am_Batman , Aug 31, 2018 :
    Download the zip file from the website.
    Clear cache and reset your phone.
    Click on done. Copy the file to your internal storage.
    Flash it from internal storage.
    Clear cache.
    Reboot.
    Sahilkum and Vladut123 like this.
  8. I_am_Batman
    KitKat Aug 31, 2018
  9. MJ_Vikram
    KitKat Aug 31, 2018
    MJ_Vikram , Aug 31, 2018 :
    i suggest you to stay with stable version.. if you are so are worried of data..
  10. Shareef Mahaboob
    Gingerbread Aug 31, 2018
  11. F1532426719188
    Eclair Aug 31, 2018
  12. Shareef Mahaboob
    Shareef Mahaboob , Aug 31, 2018 :
    mostly after 4 months or above
    Luis Sismeiro and Vladut123 like this.
  13. G_Darius_Foodei_xmYJ
    Froyo Aug 31, 2018
    G_Darius_Foodei_xmYJ , Aug 31, 2018 :
    blur the background more cuz the software works super well in the aperture mode but once the pic is taken it removes the blur‍♂️
  14. sameertarapathi
    Eclair Aug 31, 2018
    sameertarapathi , Aug 31, 2018 :
    hi all
    can some one please help me to be beta tester
    I have already downloaded the beta file straight to my phone and also restarted pressing the power and volume button, but nothing is happening
    can some one please help?
  15. AAbbas08
    Eclair Aug 31, 2018
  16. GopalB.
    Nougat Aug 31, 2018
    I'll just copy paste the instructions from the website... (from recovery mode...)
    1. Shut down your device and turn it back on while holding the power and volume down buttons simultaneously.
    2. Choose "Install from internal storage/Install from local", find your .zip file and click on "Install" to confirm.
    3. Wait a while, your phone should now update to the selected build and reboot automatically to take you into OxygenOS.
    4. You'll have to clear everything (factory reset) once this is done...
    Vladut123 and Sahilkum like this.
  17. Akhi_reddy
    Akhi_reddy , Aug 31, 2018 :
    Guys I want to go for open beta on my OP5 which is my daily driver, is it good , please suggest me....!!
  18. Daan_Eekhofアニメ
    Jelly Bean Aug 31, 2018
  19. Shareef Mahaboob
    bro go on open beta it comes faster updates than stable version
    in open beta 2 months back comes with new system ui there is no sign in stable version about new system ui
    Vladut123 and Chandra.Akhil like this.
  20. Akhi_reddy
    Are you facing any issues?
    Vladut123 and Shareef Mahaboob like this.
