182
OxygenOS Open Beta 18 for the OnePlus 5 and Open Beta 16 for OnePlus 5T
  1. Adidz Gingerbread Sep 14, 2018
    Adidz, Sep 14, 2018 :
    Worked fine with me. Try clearing app cache. Might solve the issue.
    Ravi BINAVAT, Vladut123 and HATHEEMPP like this.
  2. srinikethan Froyo Sep 14, 2018
    srinikethan, Sep 14, 2018 :
    I tried...multiple times...uninstalled and reinstalled...still the same issue .and it's only on WiFi...works well on mobile data...I'm not understanding this at all
    Ravi BINAVAT and Vladut123 like this.
  3. Adidz Gingerbread Sep 14, 2018
    Submit a bug report to Pubg mobile support when the game starts on mobile data, they usually reply in 4-5 hrs. I don't think oneplus will be able to help here.
  4. MJ_Vikram KitKat Sep 14, 2018
    MJ_Vikram, Sep 14, 2018 :
    while loading pubg you will option to repair click it and try..
  5. srinikethan Froyo Sep 14, 2018
    tried that as well...seems to not work
  6. dazlidon Froyo Sep 14, 2018
    dazlidon, Sep 14, 2018 :
    battery life has decreased.
    what the hellll are you doing with each upgrade.from 1 day baterry now it lasts only 4 hours.
    also after performing a clear cache this is how the battery looks like for a long period of time:
  7. vohra_moin Eclair Sep 14, 2018
  8. gorneanu Gingerbread Sep 14, 2018
    gorneanu, Sep 14, 2018 :
    It's unbelievable how these beta's are coming and everybody is still complaining...every single time. Battery drain (which for most OP users the naming is battery back-up ...no comment), heating issues, PUB G, lag etc. In the end, the stable version comes and everything is OK but you cannot seem to hold off for 2 weeks in order for the improvements to get to you. No, you always want the beta which always causes you trouble and you keep wining. Think of the Samsung users which get an update MAYBE once a month and that is just the security patch. Think of how they get the next OS update, 8 months after it's released and 4-5 after OP users get it. OP really does a great job with updates. With limited resources they manage to keep updating 3-4 phones and keep most of their customers happy. Stop it. Really. Want the latest, go out and spend $700 on a Pixel and that's it.
  9. HATHEEMPP Eclair Sep 14, 2018
    HATHEEMPP, Sep 14, 2018 :
    dude.....Just wanted to know whether everyone is facing this problem. So Chill......This platform is to discuss this sort of things
  10. Intruder71 KitKat Sep 14, 2018
    Intruder71, Sep 14, 2018 :
    No problems here
  11. simoniub Gingerbread Sep 14, 2018
    simoniub, Sep 14, 2018 :
    Where did you get OB 17 on 5T? This thread is for OB 18 for OP 5 and 16 for OP 5T
    Then how you are on OB 17 on 5T?
    Ravi BINAVAT, Vladut123 and Imdbadguy like this.
  12. Braedach Eclair Sep 14, 2018
  13. Imdbadguy Honeycomb Sep 14, 2018
    Imdbadguy, Sep 14, 2018 :
    Right, my bad, will change it right away
    Ravi BINAVAT, Vladut123 and simoniub like this.
  14. Tomaz_Stilwell Donut Sep 14, 2018
  15. Shhariprasath Froyo Sep 14, 2018
    Shhariprasath, Sep 14, 2018 :
    battery consumption is not affected in this update. it is same as the open beta 15.
    but I experienced unexpected reboot while in call.
  16. Intruder71 KitKat Sep 14, 2018
    Wouldn't worry about it... Unless it happens frequently
  17. P1524723582455 Cupcake Sep 14, 2018
    P1524723582455, Sep 14, 2018 :
    that's the problem
  18. Intruder71 KitKat Sep 14, 2018
    No problem it's the way oneplus works..
  19. Mr_Cyrox KitKat Sep 14, 2018
    Mr_Cyrox, Sep 14, 2018 :
    No one wants a half-baked pie...
    Just have to be patient enough until they get it done perfectly*...
    *At least by OnePlus standards
  20. Mr_Cyrox KitKat Sep 14, 2018
    1 message, 0 likes?
    My welcoming system triggered...
    Welcome to the forum please start here as your "start point": https://forums.oneplus.com/forums/starting-point
    Also please read the community guide lines:
    https://forums.oneplus.com/threads/required-reading-oneplus-community-guidelines.544846
    And the forum terms & rules:
    If you feel like you are experiencing a problem that you can't find a solution to by searching like a normal person would try reporting the issue here:
    http://forums.oneplus.com/feedback
    Remember there are no OnePlus employee here it's only users like you and me...
