154
OxygenOS Open Beta 18 for the OnePlus 6 and Open Beta 10 for OnePlus 6T
  1. Pradeep_agarwal Cupcake May 22, 2019
  2. Shahid211 Cupcake May 23, 2019
    Shahid211, May 23, 2019 :
    please share If anyone knows about update for India.
    please ignore, If you don't know
  3. Roger.T Jelly Bean May 23, 2019
  4. Shahid211 Cupcake May 23, 2019
    Roger.T likes this.
  5. Roger.T Jelly Bean May 23, 2019
    Roger.T, May 23, 2019 :
    Will also come for 6 + 6T. Is at the bottom of the article...[e]1f609[/e]
  6. Faisal92 Cupcake May 23, 2019
    Faisal92, May 23, 2019 :
    hello everyone there
    add some customization app like Samsung's Good Lock app.
    I'm using oneplus 6T.
  7. Kytharsis Marshmallow May 23, 2019
    drl431 likes this.
  8. Roger.T Jelly Bean May 23, 2019
    Bloatware and useless...
    Kytharsis and drl431 like this.
  9. ~VASANTH~ Cupcake May 23, 2019
    ~VASANTH~, May 23, 2019 :
    still oneplus 6 doesn't improve front camera quality after android pie update.we want better solution...
  10. Faisal92 Cupcake May 23, 2019
    a separate app will enable user to uninstall if you dont like or dont use,but I think it adds a bit more customization.
  11. Amollewis Froyo May 23, 2019
    Amollewis, May 23, 2019 :
    Totally agree vasant one plus needs to improve camera quality. Pixel have amazing software for camera. Probably one plus should reconsider its camera software recruitment or work on new software optimisation earlier before its too late.
  12. Shahid211 Cupcake May 23, 2019
    Thanks
  13. W1553351314454 Gingerbread May 23, 2019
  14. xorwin Cupcake May 23, 2019
    xorwin, May 23, 2019 :
    could anyone confirm that GPay works on Beta 18 for op6?
    can you remove and add the card back?
  15. leizhang123 Donut May 23, 2019
  16. dermot33 Ice Cream Sandwich May 23, 2019
    dermot33, May 23, 2019 :
    W1553351314454
    Next beta update is going to be huge unlike previous update​
    with a bit of luck,well overdue some new features at this stage
  17. zoran81 Jelly Bean May 23, 2019
    zoran81, May 23, 2019 :
    Yes
    drl431 and ironass like this.
  18. drl431 KitKat May 23, 2019
    drl431, May 23, 2019 :
    Maybe, or the one after... As betas come about every 2 weeks.
    ironass and Kytharsis like this.
  19. syedrhashmi Cupcake May 23, 2019
    syedrhashmi, May 23, 2019 :
    only 1 bug I found till now
    Camera app is hanging up immediately after going to portrait selfie in this Beta version for OnePlus 6T
    Hope this will be solved
  20. B_Wrath Marshmallow May 23, 2019
    B_Wrath, May 23, 2019 :
    And did you install any update manually for the camera app?
    Sun90 likes this.
