154
OxygenOS Open Beta 18 for the OnePlus 6 and Open Beta 10 for OnePlus 6T
  1. syedrhashmi Cupcake May 23, 2019
    syedrhashmi, May 23, 2019 :
    No, I didn't install any
  2. B_Wrath Marshmallow May 23, 2019
    B_Wrath, May 23, 2019 :
    What's the camera app version?
  3. syedrhashmi Cupcake May 23, 2019
    3.2.91
    which is the same received in this Beta ROM
  4. Sun90 Starting Point Expert May 23, 2019
    Sun90, May 23, 2019 :
    Isnt 3.0.37 the version that comes with beta for you.
    Since 3.2.91 is meant for the op7 pro afaik, which installed on older device will have this portrait issue.
    ironass likes this.
  5. syedrhashmi Cupcake May 23, 2019
    ok
    thanks
    and there is one more bug I found
    Live wallpaper is working by default on lock screen not on home screen
  6. Sun90 Starting Point Expert May 23, 2019
    As far as the live wallpaper issue.
    Try a different launcher and see if the same issue there to or not.
  7. devesh darji Gingerbread May 23, 2019
    devesh darji, May 23, 2019 :
    which wallpaper default or third party? If they are from APK of 7 pro will not work.
  8. B_Wrath Marshmallow May 23, 2019
    Nope. You received 3.0.37 in this build.
    You installed it manually.
    ironass and Kytharsis like this.
  9. devesh darji Gingerbread May 23, 2019
    uninstall this version otherwise people got in trouble and had to reset. Don't use Zenmode, camera of 7 pro in 6 or 6t
  10. syedrhashmi Cupcake May 23, 2019
    downloaded the said version but getting installation fail
  11. Sun90 Starting Point Expert May 23, 2019
    Just uninstall the updates on the existing ver 3.2.91.
    ironass likes this.
  12. syedrhashmi Cupcake May 23, 2019
    No option to uninstall update
    can be either Disabled or Forced stop
  13. Sun90 Starting Point Expert May 23, 2019
    Hit the three dots menu overflow on top right in that screen .
    ChristianHeilos likes this.
  14. syedrhashmi Cupcake May 23, 2019
    Got it
    thanks
    camera version is now 3.0.37 and its working fine
  15. syedrhashmi Cupcake May 23, 2019
  16. S7014973290 Cupcake May 23, 2019
  17. Sun90 Starting Point Expert May 23, 2019
    Sure.
  18. Sun90 Starting Point Expert May 23, 2019
    Upcoming beta update might have it.
    S7014973290 likes this.
  19. syedrhashmi Cupcake May 23, 2019
    Can't we switch Camera while recording videos.
    Nit sure but I think I used this feature in some custom ROM of other device
  20. ChristianHeilos Froyo May 23, 2019
    ChristianHeilos, May 23, 2019 :
    Thank you. That helped!
    Sun90 likes this.
