154
OxygenOS Open Beta 18 for the OnePlus 6 and Open Beta 10 for OnePlus 6T
  1. G_Vitthalbhai_V_Patel_DY Donut May 26, 2019
  2. G_Chee_Seng_vsTK Donut May 26, 2019
    Amollewis likes this.
  3. Amollewis Froyo May 26, 2019
    Amollewis, May 26, 2019 :
    Brother it will be fixed in some more updates but we are not sure when probably somewhere this year but no ETA
    #ONEPLUSFAMILY
  4. schreder Gingerbread May 26, 2019
    schreder, May 26, 2019 :
    one day after you change your phone.
    G_Chee_Seng_vsTK likes this.
  5. Vardhanrishi Cupcake May 26, 2019
  6. G_Chee_Seng_vsTK Donut May 26, 2019
  7. Amollewis Froyo May 26, 2019
    Beta testing is on its way one plus is gonna fix it in future updates as they promised.
    #Oneplusfamily
  8. drl431 KitKat May 26, 2019
    drl431, May 26, 2019 :
    Its a balancing act that OnePlus has to perform...
    Kill too many background apps, then memory management complainers get angry.
    Kill too few background apps, then battery complainers get angry.
    Maybe with Q things will be better.
  9. khyathi123 Froyo May 26, 2019
    khyathi123, May 26, 2019 :
    only open betas and public betas is there. any stable updates coming to the one plus 6.
    atleast give the security patches
  10. drl431 KitKat May 26, 2019
  11. Amollewis Froyo May 26, 2019
    Wish the same brother fingers crossed with Q things should be fixed.
    #Oneplusfamily
  12. Roger.T Jelly Bean May 26, 2019
    Roger.T, May 26, 2019 :
    Basically depends on what Google does..
    RAM management is basically up to their crap [e]1f609[/e]
    Kytharsis likes this.
  13. Aakib Shaikh Cupcake May 26, 2019
    Aakib Shaikh, May 26, 2019 :
    but please send link to install gcam port .i did not got it ...to finding please .
  14. schreder Gingerbread May 26, 2019
    you can install custom rom. it have wonderful ram management
  15. Saenz4931 Honeycomb May 26, 2019
    Saenz4931, May 26, 2019 :
    Google it. you will spend less time asking for things put in your hands or waiting for someone to do things for you. XDA developers is all you needs for hacks and mods
    B_Wrath, Shajahankm and trafalger888 like this.
  16. Aakib Shaikh Cupcake May 26, 2019
  17. C1554475418942 Donut May 26, 2019
    C1554475418942, May 26, 2019 :
    i have same problem. I can not make adaway work. could you solve it?
  18. ironass KitKat May 26, 2019
  19. C1554475418942 Donut May 26, 2019
  20. ironass KitKat May 26, 2019
    ironass, May 26, 2019 :
    The System partition is choc-a-bloc full. Try the following...
    Adaway > Menu > Preferences > Target hosts file > try selecting /data/data/hosts... see if that works
    Kytharsis and C1554475418942 like this.
