99
OxygenOS Open Beta 18 for the OnePlus 7 Pro and 7
  1. Artemus.
    Community Hero 2020 Sep 23, 2020
    Artemus. , Sep 23, 2020 :
    Beta 18 is newer than 10.3.4. You'll need to downgrade to go back to stable.
  2. rajshah2412
    Honeycomb Sep 23, 2020
    rajshah2412 , Sep 23, 2020 :
    Thanks for the update information @Abdul B.
    Looks like a great update. Can't wait to try it out.
    Thanks to the team for continuously making our experience better.
  3. Mahesh Bishnoi
    Gingerbread Sep 24, 2020
    Mahesh Bishnoi , via OnePlus 7 Pro , Sep 24, 2020 :
    Everyday I disable it because the bars near the edge of the screen is too annoying, it shows every time I go back to homescreen. Even after selecting none for voice and input in the default apps the phone keeps reverting back to Google as default on its own.
  4. G1568229794735
    Froyo Sep 24, 2020
    G1568229794735 , via OnePlus 7 , Sep 24, 2020 :
    Randomly but permanent problem with entering into sleep mode since ob17. My op7 very often doesn't enter into sleep mode after waking up by screen tap or by pick up the phone...
  5. kingslim
    Eclair Sep 24, 2020
  6. Artemus.
    Community Hero 2020 Sep 24, 2020
  7. sidm92
    Donut Sep 24, 2020
  8. Tumio
    Tumio , via OnePlus 7 Pro Nebula Blue , Sep 24, 2020 :
    once I enter this command with Termux, do I have to load it all night?
  9. D.Sai Suhail Baba
    Ice Cream Sandwich Sep 24, 2020
    D.Sai Suhail Baba , Sep 24, 2020 :
    I hope [e]1f446[/e] this will help you but update schedule may change based on Beta updates and Software compatibility issues with OnePlus devices.
  10. C1561909852980
    Cupcake Sep 24, 2020
    C1561909852980 , Sep 24, 2020 :
    Anyone else got a huge google play store battery drain? Any fixes apart from waiting for Google update?
  11. Swejuggalo
    Community Bug Hunter Sep 24, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 24, 2020 :
    Really odd. On my phone the issue is now fixed in the newest beta. Hope it will for you too in next beta. Hopefully you can get it verified by other users on the same phone and software version.
    If nobody can replicate your issue or if it happens for everyone is nice to know. And ofcourse to report it via the feedback tool.
  12. Swejuggalo
  13. Swejuggalo
    This command does the same thing a nightly charge does automatically. When doing it manually you are not forced to do it via a nightly or extended charge
  14. The_Rock90
    Jelly Bean Sep 24, 2020
  15. Artemus.
    Artemus. , Sep 24, 2020 :
    3 years and still haven't learned about proper battery post etiquette. Graphs. Are. Needed.
  16. prabhuomniau
  17. gayer
    Eclair Sep 24, 2020
  18. Artemus.
    Beta 19 will be next month and no it will not. Android 11 isn't gonna be available till next year.
