254
OxygenOS Open Beta 19/10 for the OnePlus 3/3T
Thread Status:
Not open for further replies.
  1. Galahad95
    Froyo Jul 5, 2017
    Galahad95 , Jul 5, 2017 :
    Yes, by sideloading beta zip over official firmware you won't loose any data. Anyway, I suggest you to do a clean flash, in order to avoid strange issue (or battery drains)
    damithde and zoestar like this.
  2. harshil1903
    Jelly Bean Jul 5, 2017
    harshil1903 , Jul 5, 2017 :
    Yeah, the sooner the better.. I want that watermark feature..
  3. harshil1903
    I don't need those dual camera features.. I just want other features like the shot on oneplus watermark..
  4. ssaikiran92
    Honeycomb Jul 5, 2017
    ssaikiran92 , Jul 5, 2017 :
    while accepting or rejecting calls, the circle of phone symbol to accept or reject calls is getting cut a little bit. This is a display issue.
    it doesn't look good
  5. G_SWAPNIL_PILARE_ZABW
    Donut Jul 5, 2017
  6. G_Karthik_Rengarajan_tLd
    Cupcake Jul 5, 2017
  7. adpro
    KitKat Jul 5, 2017
    adpro , Jul 5, 2017 :
    No
    varma246 and Bobbie63 like this.
  8. tpati
    Gingerbread Jul 5, 2017
    tpati , Jul 5, 2017 :
    If I do a dirty install with this beta what's appens if I do a factory reset after that? That's made a "clean install", there is a real difference?
    I'm full stock with stable version.
    What I think about dirty install is download open beta then put on folder menu and finally do a upgrade by a local update..
    Clean install is the method on oneplus site.
    There's difference between clean and "dirty" install? How this dirty install is so "dirty" vs clean if after a dirty install I do a factory reset?
  9. pratheek1992
    Donut Jul 5, 2017
    Sahilkum likes this.
  10. Owoturo Oluwatimi
    Froyo Jul 5, 2017
  11. saikiran4ever
  12. iamrajeev
  13. hgbsbi
    Cupcake Jul 5, 2017
  14. G_Janagan_Elangovan_mFXd
    Eclair Jul 5, 2017
  15. Funk Wizard
    Moderator Moderator Jul 5, 2017
  16. [email protected]+
    Ice Cream Sandwich Jul 5, 2017
    [email protected]+ , Jul 5, 2017 :
    Dirty Flash means you just flash Beta or Stable version over that you are on present without wiping data or cache, not the method of installing as you said. And clean flash means you just do a complete wipe of cache at least and then go ahead. I usually use both methods (sideload via PC and installing from internal storage from stock recovery) and wipes cache both before and after flashing and all works perfect except one weird thing while going from Beta to Stable (ie, my apps like Phone, Messaging, Contacts FC and have to factory reset and then data too will be wiped).
  17. waheed0332
    Cupcake Jul 5, 2017
    waheed0332 , Jul 5, 2017 :
    Why I'm receiving beta updates about size more than 1 gb while other people receiving like only few mbs?
  18. Funk Wizard
    Funk Wizard , Jul 5, 2017 :
    It happens whenever you make alterations to your system partition, only completely stock users would get the incremental OTA rest have to download and install the full zip
  19. pk1308
    Cupcake Jul 5, 2017
    pk1308 , Jul 5, 2017 :
    how to install
  20. Quatret
    Donut Jul 5, 2017
    Quatret , Jul 5, 2017 :
    My op 3t on oxygen os open beta 10. This morning, while im just listening to spotify, my 3t suddenly rebbot by it self. usually it will rebbot, then ask for my password, then loafing again. This time, it didnt, ut just rebbot like a normal phone so fast. Then when its start, the media sound cant make a single noise. the notification sound work perfect. I reboot my phone again, it fix, the media sound is fix.
    but i dont know what triggers this bug, and this bug is serious one if it gets me again. Any solution?
    thx.
