189
OxygenOS Open Beta 19 for the OnePlus 5 and Open Beta 17 for OnePlus 5T
  1. Icecreamypie Ice Cream Sandwich Oct 11, 2018
    Icecreamypie, Oct 11, 2018 :
    No, but it is hard to unlock
  2. Juampii17 Gingerbread Oct 11, 2018
    Juampii17, Oct 11, 2018 :
    with fingerprint?
  3. Icecreamypie Ice Cream Sandwich Oct 11, 2018
  4. G_Shariq_Hussain_fjoS Donut Oct 11, 2018
  5. pawan.chitta Donut Oct 11, 2018
    pawan.chitta, Oct 11, 2018 :
    yes I am having similar issue after the last Open beta update
    Raised issue on feedback tool
    awaiting some fix in next beta release
  6. Juampii17 Gingerbread Oct 11, 2018
    i have the op5 since it came out and no problem with unlocking. when was the last time you did a clean oos install?
  7. Icecreamypie Ice Cream Sandwich Oct 11, 2018
    I have this problem in both stable and beta
  8. Mr_Cyrox KitKat Oct 11, 2018
    Mr_Cyrox, Oct 11, 2018 :
    No problems here about it...
  9. Icecreamypie Ice Cream Sandwich Oct 11, 2018
  10. Icecreamypie Ice Cream Sandwich Oct 11, 2018
    You are lucky then or your password is easy
  11. Mr_Cyrox KitKat Oct 11, 2018
    Yeah my fingerprint is easy to remember ;)
  12. Icecreamypie Ice Cream Sandwich Oct 11, 2018
  13. Juampii17 Gingerbread Oct 11, 2018
    you mean typing fast the password? and sometimes it doesn't recognize the numbers?
  14. Icecreamypie Ice Cream Sandwich Oct 11, 2018
    Maybe his password is 1234
  15. Mr_Cyrox KitKat Oct 11, 2018
    Is this "he" me?
    If yes I have a complicated pattern...
    No way that it's weak ;)
  16. Icecreamypie Ice Cream Sandwich Oct 11, 2018
    Yes
    And my password is easy to guess
  17. Mr_Cyrox KitKat Oct 11, 2018
    Well then you just can't type well ;)
    No offense
  18. dattaprasad.patil.88 Froyo Oct 11, 2018
    dattaprasad.patil.88, Oct 11, 2018 :
    yes, this happens to me mostly when I receive or dial a call. If the screen is off then I need to press power button 3 to 4 times.
    This issue is since ob18 for me.. Thought ob19 will fix but it didnt. If next OB doesnt fix this I will probably try to factory reset my phone, as I had jumped into OB from stable without a reset.
    G_Shariq_Hussain_fjoS likes this.
  19. Mr_Cyrox KitKat Oct 11, 2018
    That probably could be it...
    I never experienced that kind of behavior...
    I always recommend a factory reset with data wipe when going to Open Beta...
    I'm going to do a full wipe after Pie build is out ;)
    dattaprasad.patil.88 likes this.
  20. Icecreamypie Ice Cream Sandwich Oct 11, 2018
    How to do a full backup that backup apps, data in apps and photo and some private stuffs
