199
OxygenOS Open Beta 19 for the OnePlus 6 and Open Beta 11 for OnePlus 6T
  1. B_Wrath Marshmallow Jun 12, 2019
    B_Wrath, Jun 12, 2019 :
    Oh my God. I'm not able to understand what you are saying.
    Be clear. Use punctuations. Or is your language. Summertime who understands it will try to reply.
    Kytharsis and ironass like this.
  2. B_Wrath Marshmallow Jun 12, 2019
    I was thinking of writing such a post. It should be pinned in the latest beta thread.
    Kytharsis, ironass and drl431 like this.
  3. fatehbajwa Cupcake Jun 12, 2019
    fatehbajwa, Jun 12, 2019 :
    I tried the method given by karna... 8 replies above this comment. It worked.
    Now i wonder if I should have done it.
  4. YasSkiller Gingerbread Jun 12, 2019
    YasSkiller, Jun 12, 2019 :
    I can write on french ? im not english but i think we can understand what i wrote before
  5. B_Wrath Marshmallow Jun 12, 2019
    Yes. You can write in French.
    The last post lacks any punctuation and is really difficult to understand.
    Kytharsis likes this.
  6. YasSkiller Gingerbread Jun 12, 2019
    En fait, quand je lance l'enregistreur d'écran, l'ajustement du volume bug. Par exemple, si j'augmente le volume et que l'animation est fermé, le niveau du volume revient comme avant ! Et parfois quand j'appuie sur les boutons de volume, ça fait rien ! Et si je mets mes écouteurs, on n'entend plus rien. Ainsi que quand je vais voir la video enregistrée en galerie, Le song n'est enregistré totalement.
  7. ironass KitKat Jun 12, 2019
    ironass, Jun 12, 2019 :
    Were you already on Open Beta before?
  8. fatehbajwa Cupcake Jun 12, 2019
  9. Sidhaarth mutreja Froyo Jun 12, 2019
    Sidhaarth mutreja, Jun 12, 2019 :
    also go the Play Store search digital well-being and update your application it won't automatically appear in updates
  10. Q1535196119076 Froyo Jun 12, 2019
    Q1535196119076, Jun 12, 2019 :
    I flashed it...and It shows like this....O was running the latest stable before
    wolf4477 likes this.
  11. badulla.p Gingerbread Jun 12, 2019
    badulla.p, Jun 12, 2019 :
    It's appearing
  12. wolf4477 Eclair Jun 12, 2019
  13. B_Wrath Marshmallow Jun 12, 2019
    Ah ce bug. Je n'ai pas eu l'occasion de le tester. vous pouvez fournir un retour sur le canal de retour.
    YasSkiller likes this.
  14. YasSkiller Gingerbread Jun 12, 2019
    Où ça le canal de retour ?
  15. B_Wrath Marshmallow Jun 12, 2019
    drl431 likes this.
  16. devesh darji Gingerbread Jun 12, 2019
    devesh darji, Jun 12, 2019 :
    On XDA file shared has date of 10/6/19.
    link is below
    https://androidfilehost.com/?fid=6006931924117893706
  17. devesh darji Gingerbread Jun 12, 2019
    Download from XDA androidfilehost. They may have newer date.
  18. B_Wrath Marshmallow Jun 12, 2019
  19. NodePoint Froyo Jun 12, 2019
    NodePoint, Jun 12, 2019 :
    What animation are you referring to? The volume slider does not appear to be adjusting by itself during or after the recording on my end..
  20. Aryanbhatt Froyo Jun 12, 2019
