199
OxygenOS Open Beta 19 for the OnePlus 6 and Open Beta 11 for OnePlus 6T
  1. B_Wrath Marshmallow Jun 12, 2019
    B_Wrath, Jun 12, 2019 :
    You can't change the volume once screen recording is on. It stays either full or zero. The slider will show movement, but the volume won't actually change.
  2. B_Wrath Marshmallow Jun 12, 2019
  3. ironass KitKat Jun 12, 2019
    ironass, Jun 12, 2019 :
    I am beginning to think that the 3 posters mentioned in my earlier post, #1801, may have downloaded the old Open Beta releases, 19 & 11, from the OnePlus Download store, or similar.
    Nah... all 3 couldn't be that daft... could they?
    Will cross out that post until I can confirm. :confused:
    B_Wrath and Kytharsis like this.
  4. B_Wrath Marshmallow Jun 12, 2019
    Anything can happen in oneplus forums.
  5. B_Wrath Marshmallow Jun 12, 2019
    ironass likes this.
  6. Aryanbhatt Froyo Jun 12, 2019
  7. ironass KitKat Jun 12, 2019
    Kytharsis likes this.
  8. B_Wrath Marshmallow Jun 12, 2019
    Kytharsis and ironass like this.
  9. NodePoint Froyo Jun 12, 2019
    NodePoint, Jun 12, 2019 :
    That's an odd bug. Was unable to reproduce it (music was playing, volume was able to change during the recording and loudness would change in the finished recording).
  10. B_Wrath Marshmallow Jun 12, 2019
    I didn't check it on the latest beta. I did check it on the previous one and I had the bug.
    I was using wireless headphones. If that can be a problem, I don't know.
  11. Aryanbhatt Froyo Jun 12, 2019
    ironass likes this.
  12. B_Wrath Marshmallow Jun 12, 2019
    That's the old beta update. Beta 19.
    Latest is beta 20.
    @ironass you got the answer.
  13. Aryanbhatt Froyo Jun 12, 2019
  14. B_Wrath Marshmallow Jun 12, 2019
  15. ironass KitKat Jun 12, 2019
    LMAO :D
    I cannot believe that there are so many low calibre Open Beta testers that cannot even work out the correct numbering. :rolleyes:
    Will adjust my earlier post accordingly. DUH! ;)
    Kytharsis, drl431 and B_Wrath like this.
  16. Aryanbhatt Froyo Jun 12, 2019
    Aryanbhatt, Jun 12, 2019 :
    oneplus just rolled out open beta 20 i had no idea
  17. B_Wrath Marshmallow Jun 12, 2019
    Don't tell me you didn't figure that out by now:rolleyes:
    The open beta threads became idiotic sheet the first few open betas for OP3/T.
    TheAyushJain likes this.
  18. NodePoint Froyo Jun 12, 2019
    Yup. Happened with the Bullets Wireless (also noticed that if audio is currently playing then you will get no audio until the volume is adjusted). On beta 11. Do you know if it's specific to headphones/earphones or when it comes to Bluetooth audio devices in general (i.e. speakers)?
  19. B_Wrath Marshmallow Jun 12, 2019
    You would have gotten idea if you read this thread before trying to update.
  20. Aryanbhatt Froyo Jun 12, 2019
    ok faltu ka gyaan mat chod
