276
OxygenOS Open Beta 2 for OnePlus 6
  1. shubhammathur
    Donut Sep 9, 2018
    shubhammathur , Sep 9, 2018 :
    Did you mean Google Pay is not working? Or is it working now?
    Vladut123 likes this.
  2. G_Osman_Malik_nneJ
    Cupcake Sep 9, 2018
    G_Osman_Malik_nneJ , Sep 9, 2018 :
    Yeh, that the first thing I check, but it's only when you press a button,I can't remember if it used to happen on stable build.
  3. iamcrazyves
    Cupcake Sep 9, 2018
  4. G_Osman_Malik_nneJ
    Cupcake Sep 9, 2018
    I checked that, but it's off, and that shows all touches, this shows just when you press a button. I can't remember if it happened on stable or just on beta and I'm noticing now.
  5. Daredevil23
    Eclair Sep 9, 2018
    Daredevil23 , Sep 9, 2018 :
    if u want u can turn on ambient display! it's shows notification on screen with out turning on the display
  6. caldev
    Eclair Sep 9, 2018
    caldev , Sep 9, 2018 :
    anyone elses lockscreen after the update like this?
    right in the middle as opposed to near the bottom
  7. rahulkumar92
    Donut Sep 9, 2018
  8. T1533992214533
    Cupcake Sep 9, 2018
  9. premsonu118
    Froyo Sep 9, 2018
    premsonu118 , Sep 9, 2018 :
    Hello OnePlus! I am so ready for the OnePlus 6 [e]1f609[/e] thanks for the update and great news
  10. U1532055367294
    Donut Sep 9, 2018
    U1532055367294 , Sep 9, 2018 :
    working good and stable, I can see a better improvement with the battery, better and smooth multitasking, good job OP.
  11. rahulkumar92
    Donut Sep 9, 2018
  12. rahuldw181
    Ice Cream Sandwich Sep 9, 2018
  13. manasarora98
    manasarora98 , Sep 9, 2018 :
    I hope OnePlus did not forget the stable users.
    We are still on July Security Patch and we require some urgent fixes too.
  14. camohan
    Marshmallow Moderator Sep 9, 2018
    camohan , Sep 9, 2018 :
    Yes that is missing. Thread merged, pls give your feedback in main thread for devs to know.
  15. horvath.patrick
    Honeycomb Sep 9, 2018
    horvath.patrick , Sep 9, 2018 :
    There is no more cache in android 9.0. You can clear app cache app by app.
    But using the search function you'd know that by now.....
  16. aligineni
    Cupcake Sep 9, 2018
  17. F1533728391972
    Cupcake Sep 9, 2018
  18. Dr chauhan
    Donut Sep 9, 2018
  19. @iamsandy
    Gingerbread Sep 9, 2018
    @iamsandy , Sep 9, 2018 :
    does hd videos play on Netflix in oos beta 2 since it has some issues with safety net??
  20. LLcoolNJ
    Froyo Sep 9, 2018
    LLcoolNJ , Sep 9, 2018 :
    Few Feedbacks:
    Notification on ambient display doesn't show app info/icon for default messaging app and sometimes for WhatsApp as beta 1
    Unlocking is little bit slower that earlier version
    In lift up display, if you have switched off to show battery percentage, then only circle appear. It will be convenient if battery percentage is always visible during lift up display.
    Android1970, Vladut123 and Umberto_09 like this.
