275
OxygenOS Open Beta 2 for OnePlus 6
  1. JugenGounder9000
    Donut Sep 9, 2018
    JugenGounder9000 , Sep 9, 2018 :
    are you saying that i cannot clear cache on beta versions? Sorry I'm new to all of these I have no Idea.
    Vladut123 likes this.
  2. Tamukanashe Musengezi
    Gingerbread Sep 9, 2018
    Tamukanashe Musengezi , Sep 9, 2018 :
    use these steps one at a time (check app after each step) to debug if none of them work then report in feedback forum
    1)clear cache,
    2) clear app data,
    3) delete then reinstall,
    4) wipe phone and start afresh
  3. Prince00243
    Eclair Sep 9, 2018
    Prince00243 , Sep 9, 2018 :
    My favorite app, ecobank mobile keeps stopping on beta 1 and 2. Please have a look at
  4. VegardLoknes
    Eclair Sep 9, 2018
    VegardLoknes , Sep 9, 2018 :
    When using the standard Android 9 Pie swipe buttons there's this weird thing that happens when swiping directly to the right on the home button. It should be the same as tapping twice on the multitasking button, but it gets stuck on nothing.
  5. B1534925173970
    Cupcake Sep 9, 2018
  6. Dahnark
    Eclair Sep 9, 2018
    Dahnark , Sep 9, 2018 :
    you can install it from apk mirror
  7. acharyya72
    Eclair Sep 9, 2018
  8. edy90s
    Honeycomb Sep 9, 2018
    edy90s , Sep 9, 2018 :
    they need to fix camera , that s all , we have dash charge......they should work for camera to make it better 5.1.11 have serious problems for back and front camera focus blurred pictures etc that's the reason I stay to 5.1.6 and won't update till the reviews will be good :)
  9. Fixxer
    Froyo Sep 9, 2018
    Fixxer , Sep 9, 2018 :
    I'm not receiving any mobile data after Open Beta 2 although the signal is good. I didn't encountered this after upgrading to Android 9 Beta.
    anyone else facing this issue?
    LE: solved it with a simple restart...
  10. karthik.pk
    Donut Sep 9, 2018
    bojler and Vladut123 like this.
  11. Shaji06
    Froyo Sep 9, 2018
    Shaji06 , Sep 9, 2018 :
    Hi
    please Enabled in Navigation gusture with back button.
    then go to Dial pad and search contact some details hidden top then how to i select my option may be that.???
    please check and fix it ASAP.
    Reg,
    Shajith Khan
  12. jid_77
    Eclair Sep 9, 2018
    jid_77 , Sep 9, 2018 :
    Guys seriously, you are amazing! Downloading now. Thank you for your great work
  13. arnav_89
    Froyo Sep 9, 2018
    arnav_89 , Sep 9, 2018 :
    Anyone else facing an issue with lift up display when the night mode is one? The time/date and other information is solid red color. This doesn't happen when I turn off night mode.
  14. StephenRJ
    Eclair Sep 9, 2018
    StephenRJ , Sep 9, 2018 :
    Thats probably not a ROM issue, but an app compatibility issue. App developers will have to update their apps to be compatible with Android P. They stated in the OP of the beta 1 thread that not all apps will be. Give the developer time to update it.
    Fingerprint is as fast as ever for me. Did you dirty flash or wipe after install? As a first step, you could try removing the fingerprint data and re-adding it. If that still does not work, backup your data to an external source, wipe your phone and try again.
  15. gaster
    Lollipop Moderator Sep 9, 2018
    gaster , Sep 9, 2018 :
    That was fast. Thanks Manu!
  16. Q1533492076261
    Cupcake Sep 9, 2018
    Q1533492076261 , Sep 9, 2018 :
    When the official OTA is released. Do I have to wipe all of my data to update from the BETA OTA to the Official OTA ?
    Thanks.
  17. arc4num
    Cupcake Sep 9, 2018
    arc4num , Sep 9, 2018 :
    ye, it is slow when I unlock phone without waking up with power button.
  18. Ryster
    Froyo Sep 9, 2018
    Ryster , Sep 9, 2018 :
    assuming it continues into OB3, 4, 5 and beyond, I'm loving the pace of beta releases. I can't jump aboard until the G Pay issue is resolved. Will OB3 be the one?
  19. bkeaver
    Froyo Sep 9, 2018
    bkeaver , Sep 9, 2018 :
    G_Siddhant_Mayekar_RRFM
    It was working in open beta 1​
    how is Google pay working when NFC isnt
  20. TushJain
    Cupcake Sep 9, 2018
