276
OxygenOS Open Beta 2 for OnePlus 6
  1. D1527613082077
    Cupcake Sep 9, 2018
    F1536011049830 and Vladut123 like this.
  2. vinaykrsingh
    Eclair Sep 9, 2018
    vinaykrsingh , Sep 9, 2018 :
    Comparatively better but face unlock and fingerprint seems slow as compared to Oreo.
    Adding some new fonts will be of great help.
    Vladut123 likes this.
  3. rolandflores16
    Froyo Sep 9, 2018
    rolandflores16 , Sep 9, 2018 :
    You might be in developer's preview.
    Your OxygenOS version should be like this (check the screenshot)
  4. D1527613082077
    Cupcake Sep 9, 2018
  5. Idrisgandhi10
    Cupcake Sep 9, 2018
    Idrisgandhi10 , Sep 9, 2018 :
    Can anyone help me out on how to enter into recovery mode in android pie? I cant seem to find any advanced reboot option . And pressing volume down button and power button does not seem to work. I am new to this, please bear if the question has been asked before. Thanks
  6. Dunil wadaskar
    Eclair Sep 9, 2018
    Dunil wadaskar , Sep 9, 2018 :
    ok sir.. so what i have to do right now to get in beta 2?
  7. D1527613082077
    Cupcake Sep 9, 2018
  8. Dunil wadaskar
    Eclair Sep 9, 2018
  9. rutwikparmar
    Eclair Sep 9, 2018
    Vladut123 and D1527613082077 like this.
  10. rolandflores16
    Froyo Sep 9, 2018
    it is not called "beta". it is "open beta" don't get confused. first step is you need to install open beta first. after installing you will receive open beta 2 as an OTA. :)
  11. devoncatt
    Gingerbread Sep 9, 2018
    devoncatt , Sep 9, 2018 :
    One plus switch asks me to put one plus switch on another phone and copy the QR code it does not seem to just form a backup on my OP6 phone.
  12. Dunil wadaskar
    Eclair Sep 9, 2018
    thank you soo much sir for help and support.. and thak u for understanding me a difference
    Vladut123 and rolandflores16 like this.
  13. vinaykrsingh
    Eclair Sep 9, 2018
    Dark theme should also be extended to others apps like OnePlus community, calender , downloads..
  14. AkbarKhan96
    Donut Sep 9, 2018
    AkbarKhan96 , Sep 9, 2018 :
    round the top of the phone off under the status bar doesn't look right when watching videos
  15. rolandflores16
    Froyo Sep 9, 2018
    no problem. we're here to help each other. cheers! never settle!
    Dunil wadaskar and Vladut123 like this.
  16. Rk_1305
    Cupcake Sep 9, 2018
    Rk_1305 , Sep 9, 2018 :
    after updating to Android p open beta 2. front cam is not working properly. image getting blurred. can anyone suggest anything for that or else please roll out an update
  17. Santhosh Ambasankar
    Donut Sep 9, 2018
    Santhosh Ambasankar , Sep 9, 2018 :
    How to downgrade it bro?
  18. Pranav Peddi
    Honeycomb Sep 9, 2018
    Pranav Peddi , Sep 9, 2018 :
    did you sideload the app, because it is showing as app incompatible on play store.
  19. devoncatt
    The Instructions at the beginning of the thread download to computer and transfer to your OP6 . I've done so then I will do the local update option
  20. Santhosh Ambasankar
    Donut Sep 9, 2018
    Ambient display is not working properly... It should be in white colour... But after update it is in yellow colour... Did anyone notice this?
    And auto brightness is not working..
