276
OxygenOS Open Beta 2 for OnePlus 6
  1. rolandflores16
    Froyo Sep 9, 2018
    rolandflores16 , Sep 9, 2018 :
    Okay. Good to hear that. But what is the yellow tint that everybody is talking about? Can't seem to find it on my phone.
    Vladut123 likes this.
  2. Funk Wizard
    Lollipop Moderator Sep 9, 2018
    Funk Wizard , Sep 9, 2018 :
    For those who use the night mode, the display conflicts with it for now
    Vladut123, otto2 and rolandflores16 like this.
  3. otto2
    Photography Expert Sep 9, 2018
  4. ashwinmurali
    Honeycomb Sep 9, 2018
    ashwinmurali , Sep 9, 2018 :
    Guys, what is AVG. SOT??? with OB1 & OB 2, im getting max to max 5hrs 30minutes. While in Oreo, it was like 6.30hrs - 7.00hrs and at times i even got 8 hours according to my usage pattern. I know Betas are not that optimised as that of stable versions. Still out of curiosity are you getting the same kind of battery backup after upgrading or reduced like mine??? Even HOS/DP versions was much better in terms of SOT, as i used to get min 6hours. Please feel free to replay.
  5. rolandflores16
    Froyo Sep 9, 2018
    Oh. okay. thanks for clearing that up.
  6. arnav_89
    Froyo Sep 9, 2018
    arnav_89 , Sep 9, 2018 :
    Oneplus does not have a calendar app. You should send a request to Google (or the developer of whichever calendar app you use). But I agree, the other 2 should have dark theme to keep the ui more consistent.
  7. horvath.patrick
    horvath.patrick , Sep 9, 2018 :
    Volume rocker primarily adjusts media volume over ringtone/notifications.
    This one is not a bug, it's by design so from Android Pie
    faceunlock/fingerprint is fine
    Screen brightness is also fine.
    anilchelli, Vladut123 and Aks41179 like this.
  8. Deactivated User
    Sep 9, 2018
  9. devoncatt
    Gingerbread Sep 9, 2018
    devoncatt , Sep 9, 2018 :
    Some say yes and others disagree, Some have just downloaded it and done a local upgrade others have backed up everything cleared everything and then upgraded. Based on what I have read s far there doesn't seem to be much difference but please be aware some apps may not work under the beta but in theory you can revert to the older system but it seems to be an involved process. Your mileage may vary. I'm doing the local upgrade this evening
  10. devoncatt
    Each app has a cache according to previous replies Android 9 does not have a system-wide cache you have to empty each app's cache separately
  11. G_shajahan_km_abcd
    Froyo Sep 9, 2018
  12. Intekhab145
    Intekhab145 , Sep 9, 2018 :
    well whatever issues I had with the beta 1 has been solved in beta 2.. Fast to react to the feedbacks. Thanks OnePlus.
    There is a new issue with the beta 2, when the device is in always on display mode, sometimes it doesn't unlock and take me to the home screen, when unlocked with the fingerprint. Rather it gets unlocked and stays at the on display mode and I need to manually slide up the finger to go to the home screen.
  13. devoncatt
    According to speculation ( not necessarily a fact), it should be shortly but no specific time has been mentioned officially
  14. aj2989
    aj2989 , Sep 9, 2018 :
    There is a significant reduction in the screen brightness threshold, it's way too dim at higher levels and then poof mega brightness.
    Face unlock animation is significantly slower when waking screen compared to oreo. Unless that's how it's supposed to be in P, many others and I feel it's a bug.
    Since others have reported for finger print as well, I've added it to the list.
    Not sure about the volume rocker thing - will look into it. But I would much prefer ringer/notifications control than media as native function.
  15. chazey2
    Jelly Bean Sep 9, 2018
    chazey2 , Sep 9, 2018 :
    I have a similar type of app for viewing CCTV at work. I did clean install without allowing Google to restore and mine is fine. Try clearing data and cache then uninstall and reinstall and re set up. As the first time I installed Beta 2 I allowed restore from set up and quite a few of my apps FC including the CCTV app.
    krafiq and Vladut123 like this.
  16. alex27riva
    Eclair Sep 9, 2018
    alex27riva , Sep 9, 2018 :
    I can not put full-screen Clash Royale with this new beta, the entry does not appear in the fullscreen settings
  17. aj2989
    If others report a similar bug then I will add it to the known list.
  18. devoncatt
    Delete the device from Bluetooth and reinstall it has helped when this happened in the past .
    Vladut123 and aj2989 like this.
  19. snce1980
    Donut Sep 9, 2018
    snce1980 , Sep 9, 2018 :
    seeing two noticeable issues with OB2.
    1. play store gets stuck at 100% when installing/updating apps. play store has to be restarted to finish installing.
    2. Hangouts force closes when texting/sharing via SMS.
  20. aj2989
    Wipe cache. It worked for me.
