276
OxygenOS Open Beta 2 for OnePlus 6
  1. G_prasanna_prasi_zAIN
    Eclair Sep 10, 2018
    G_prasanna_prasi_zAIN , Sep 10, 2018 :
    check wifi options in settings.... I too faced same but now it is fine
    Vladut123 likes this.
  2. Pankkajarora
    Gingerbread Sep 10, 2018
    Pankkajarora , Sep 10, 2018 :
    thanks, I checked everything but now will be checking after switching off the "smart wifi switcher"
  3. ClarKent98
    Froyo Sep 10, 2018
  4. raghunathtosh
    Cupcake Sep 10, 2018
  5. G_prasanna_prasi_zAIN
    Eclair Sep 10, 2018
    switch off to remain in the same network wifi or mobile data
  6. vinaykrsingh
    Eclair Sep 10, 2018
  7. FaleshC
    KitKat Sep 10, 2018
  8. rock51in
    Froyo Sep 10, 2018
    rock51in , Sep 10, 2018 :
    Thanks for the update.
    normally when an alarm goes off, I see notifications to snooze or to turn it off. Now i am not seeing anything and i have to go inside clock -- alarm to switch off. still no snooze.
  9. ack154
    Eclair Sep 10, 2018
    ack154 , Sep 10, 2018 :
    Is anyone's Screen Calibration / color settings resetting? I've had mine on sRGB and every few times I unlock my phone I notice its color is a little more... vibrant? I go and look at the Screen Calibration setting and it's still on sRGB but if I toggle to Default, nothing changes. If I change back to sRGB it definitely changes back to what sRGB should be.
  10. G_prasanna_prasi_zAIN
    Eclair Sep 10, 2018
    same issue
    Vladut123 and rock51in like this.
  11. Adr1ani
    Donut Sep 10, 2018
  12. James Matthew Wells
    Honeycomb Sep 10, 2018
    James Matthew Wells , Sep 10, 2018 :
    I really hope they get Google Pay up and working again. I use it quite often. Other than that, these betas are awesome so far.
  13. ack154
    Eclair Sep 10, 2018
    Google Pay should work fine with the final version. They just haven't certified it on the betas so far. I wouldn't worry too much (unless it takes forever to get the final version, that would be annoying).
  14. X1528714604501
  15. sm0kee
    sm0kee , Sep 10, 2018 :
    Hi!
    I found a major problem. For me with the new beta the messenger,viber,whatsapp and outlook and gmail is not refreshing if I using mobile network. (My provider is Vodafone) I'm the only one who facing with this issue?
    Thank You
    Vladut123 and Ashwath Reddy D K like this.
  16. varunbhavsar93
    Froyo Sep 10, 2018
    varunbhavsar93 , Sep 10, 2018 :
    Dude your report is 100% accurate and true I must commend the effort you put into this well done man!
  17. @iamsandy
    @iamsandy , Sep 10, 2018 :
    YouTube videos are playing in full-screen mode and there is no setting to change it to default mode....is it a bug?
  18. Tripledreams
    Donut Sep 10, 2018
    Tripledreams , Sep 10, 2018 :
    only issues I've encountered so far are battery drain (a little better than developer preview), notifications pop up on the lockscreen colors are too saturated (ie. use to be navy blue for messages, now it's a bright blue almost purple color) and the ambient display doesn't work even when turning on and off if you move the slider manually, that's where it will stay unless you move it back.
    edit: aside from a few other known issues, the multitasking cards seem to bunch up on each other, this is on stock launcher with OnePlus gestures turned on. 1536590583004.jpg
  19. RossThompson96
    RossThompson96 , Sep 10, 2018 :
    100% agree, is there a feature request section
  20. Intekhab145
    Intekhab145 , Sep 10, 2018 :
    After the open beta 2 update there is a fast battery drainage ... No idea what's causing it but the device doesn't seem to last a day with this update
