276
OxygenOS Open Beta 2 for OnePlus 6
  1. arnav_89
    Froyo Sep 10, 2018
    arnav_89 , Sep 10, 2018 :
    It might not be working fir o2. It's working for me.
    Vladut123 likes this.
  2. vriesdejoop
    Ice Cream Sandwich Sep 10, 2018
    vriesdejoop , Sep 10, 2018 :
    working for me to
  3. F_Dhrmesh_K_Dhameliya_xa
    Cupcake Sep 10, 2018
  4. Mika420xxx
    Donut Sep 10, 2018
    Mika420xxx , Sep 10, 2018 :
    I think my problem is a result of the fact that it's still a beta...or maybe that the apps are not optimized for Android P. I noticed extremely high battery consumption of apps like WhatsApp Telegram and some games. When screen is off the battery usage is hardly not noticeable but on-screen I can watch the percentage fall in just a few minutes. Can somebody tell me if that's a Problem with the oxygen version or with the apps from the play store?
  5. Horizon21000
    Honeycomb Sep 10, 2018
    Horizon21000 , Sep 10, 2018 :
    Do a factory reset than it should be fine :)
  6. Horizon21000
    I think itnis caused by the Youtube App itself and OnePlus can't do anything about it.
    You should write your request to Google!
    Vladut123 and S1536022592186 like this.
  7. Mika420xxx
    Donut Sep 10, 2018
    You tried it on your own or is it just an assumption?^^
  8. Horizon21000
    I think you should do a factory reset. Could be a kernel issue and the clock of the SoC runs to high.
    So far I can tell I have the same amazing battery life as in Beta 1.
    Vladut123 and Mika420xxx like this.
  9. Mika420xxx
    Donut Sep 10, 2018
    Alright thanks is your battery life as good as on the stable Oreo version? The battery life is still okay but it lasts for just around a day
  10. Horizon21000
    I can't guarantee it but battery drain on Beta 2 is not normal.
    So it must be connected to some bug which caused by flashing the update without wiping the system and data partition.
  11. Horizon21000
    I never was on Oreo with my OnePlus 6. Startet directly with Android Pie DP1.
    In DP1-3 the battery life was just avarage but on Beta 1 I just achieved 10 hours of Screen-On-Time (with light usage) what is amazing.
    So far I can tell Beta 2 seems to be the same.
  12. Kaiken
    Donut Sep 10, 2018
    Kaiken , Sep 10, 2018 :
    Hmm, first page of thread says we need to wipe for Beta 2 but the downloads page says we shouldn't have to coming from stable. So which is it?
  13. Mika420xxx
    Donut Sep 10, 2018
    Yeah alright that's light years away from everything I get...is it necessary to wipe the internal storage?
  14. ArChung1101
    ArChung1101 , Sep 10, 2018 :
    I can't even turn on the wifi and set up the fingerprint, is this normal or I need a factory reset to solve these problems?
  15. S1536022592186
    Eclair Sep 10, 2018
  16. Horizon21000
    Yes, full factory reset :-(
    Make a backup before ;-)
  17. Horizon21000
    For me it is working.
    I think you should do a factory reset to solve the issue.
  18. Horizon21000
    This is defenitly not normal and yes a factory reset is very recommended!
  19. Pradeep_kt
    Eclair Sep 10, 2018
  20. Mika420xxx
    Donut Sep 10, 2018
    Hello Back after reset still draining but i hope it's just because of downloading the Backup^^
