275
OxygenOS Open Beta 2 for OnePlus 6
  1. Mika420xxx
    Donut Sep 10, 2018
    Mika420xxx , Sep 10, 2018 :
    Hello Back after reset still draining but i hope it's just because of downloading the Backup^^
    Vladut123 likes this.
  2. Matty8787
    Froyo Sep 10, 2018
  3. Nounousss971
    Cupcake Sep 10, 2018
    Nounousss971 , Sep 10, 2018 :
    Après l'installation de la mise à jour Android pie, il n'y a plus d'images sur les chaînes de l'application MyCanal. Il n'y a que le son et aucune image. Pouvez vous me donner une solution s'il vous plaît. Merci.
  4. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Sep 10, 2018
    KeepTransisting , Sep 10, 2018 :
    You can't use the Oxygen Updater to go back to stable. You have to use the rollback package in the first post and it WILL wipe your data
    Vladut123 and Matty8787 like this.
  5. Matty8787
    Froyo Sep 10, 2018
    Matty8787 , Sep 10, 2018 :
    cheers for that I reckon I am just going to wait on full release.
    glad it is looking good though!
  6. A1536152278354
  7. Znaites
    Donut Sep 10, 2018
    Znaites , Sep 10, 2018 :
    guys i cant downgrade to other version I did a factory reset and wiped cache and etc. what I'm doing wrong ?
  8. KeepTransisting
    Are you using the special rollback package that's in the first post of this thread?
  9. Znaites
    Donut Sep 10, 2018
    no.. I can't find it sorry for being this dumb :/ can you send the link plz ?
  10. KeepTransisting
  11. Znaites
    Donut Sep 10, 2018
    im with beta 2 so im going to test it out
    That´s why i didnt find it :/ .. ok first i install that, then i do the wipe, right ?
  12. VarunNadgouda
    VarunNadgouda , Sep 10, 2018 :
    parallel apps / dual app feature not extended to Blackberry work and other apps.
    parallel space app does not work in beta version
  13. Aadi2708
  14. gubro
    KitKat Sep 10, 2018
    gubro , Sep 10, 2018 :
    English please.
    Vladut123 and Aks41179 like this.
  15. gubro
    KitKat Sep 10, 2018
    When it's ready.
    otto2, Vladut123 and Aks41179 like this.
  16. EDUB04
    EDUB04 , Sep 10, 2018 :
    The only major issue that i have faced is excessive amount of battery drain. Next, within YouTube while opening the settings while a video is being played a white stripe appears below the notch
  17. Aadi2708
    Aadi2708 , Sep 10, 2018 :
    ik it will come when it's ready but any date or something
  18. Predict23
    Ice Cream Sandwich Sep 10, 2018
    Predict23 , Sep 10, 2018 :
    Anyone using twitter? Scrolling isnt smooth at all, and its lagging since stable oreo...
  19. Znaites
    Donut Sep 10, 2018
  20. gubro
    KitKat Sep 10, 2018
    29. February 2019.
    Vladut123, Aks41179 and mdes like this.
