276
OxygenOS Open Beta 2 for OnePlus 6
  1. I1532505041165
    Cupcake Sep 11, 2018
  2. FaleshC
    KitKat Sep 11, 2018
    FaleshC , Sep 11, 2018 :
    Did you try to contact app devs about this? They need to update their apps to support Pie.
    otto2 and GambitM like this.
  3. tortoise14
    Honeycomb Sep 11, 2018
  4. Horizon21000
    Horizon21000 , Sep 11, 2018 :
    Are you useing the OnePlus Launcher? Currently the recent apps menu is part of the OnePlus Launcher. It won't work on third party launcher without issues!
  5. J1535518237687
    Froyo Sep 11, 2018
    J1535518237687 , Sep 11, 2018 :
    using OnePlus launcher... that's a bug
  6. Kasyap Girijan
    Eclair Sep 11, 2018
    Kasyap Girijan , Sep 11, 2018 :
    partially ... if u check .. if the screen is on even in pocket mode it will unlock with finger print .. but it won't unlock if the screen is off ..
  7. SpartanVissepo
    Gingerbread Sep 11, 2018
  8. Suryadeep Lall
    Suryadeep Lall , Sep 11, 2018 :
    heavy battery drain in the beta 2 version [e]1f62a[/e].. phone has started heating up while gaming..
  9. dhish42
    Froyo Sep 11, 2018
    dhish42 , Sep 11, 2018 :
    although there's 7+ hours of screen on time with every single charge I think the battery performance can be made better by reducing ambient display brightness(it's just toooo bright) earpiece volume(too loud)
    would also appreciate if the decreased speed in unlocking the phone via FP or Face Unlock is fixed. Should be top priority, this.
  10. Horizon21000
    Do a factory reset, thats not normal!
  11. Horizon21000
    I don't experience any decrease of speed in unlocking my phone in Beta 2. I think you should perform a factory reset to solve this bug on your phone!
    Tclarke-94 likes this.
  12. singh.harshjeet
    Donut Sep 11, 2018
  13. aj2989
    aj2989 , Sep 11, 2018 :
    I've added it to known issues. It seems to be some problem with Android P gesture (recent app swipe up).
    Try clearing the apps cache directly through the app and get back to me.
    Are you using mobile internet? Because some users reported similar issues when using mobile internet.
    I'm not a Dev, but I will add it to the list of known issues if it behaves the same for me or wait for more to report it.
  14. dhish42
    Froyo Sep 11, 2018
    done already, doesn't work
    it's not very slow though I just meant that it's noticeably slower than all the previous versions
  15. Shaji06
    Froyo Sep 11, 2018
    Shaji06 , Sep 11, 2018 :
    i clearer now but again same issue repeated.. What ll do now?? pl tell me to downgrade from pie to oreo..
  16. aj2989
    Try using the apps on wifi too.
    As for downgrading here are the instructions but it's from beta 1: - this will wipe your phone like a factory reset.
    Instructions for downgrading from Android P Beta version to MP version
    Rollback process:
    1. Download the latest ROM package from the specified server [HERE].
    2. Copy ROM rollback package to the mobile phone storage root directory.
    3. Settings -> system updates -> top right corner icon -> local upgrade -> click on the installation package -> immediately upgrade -> system upgrade to 100%.
    4. Select Reboot system now.
    5. Update successfully.
    Please note: This upgrade will clear all contents of the phone, please make sure to back up.
    Shaji06 likes this.
  17. rutwikparmar
    Eclair Sep 11, 2018
  18. HaloZ
    Froyo Sep 11, 2018
    HaloZ , Sep 11, 2018 :
    What are you talking about? It's still available on Beta 2
  19. Pritmhatre7
    Eclair Sep 11, 2018
  20. P1536640973511
