Known issues with Beta 2 - September 9th
Lift up display is buggy - flashes quickly to yellow and then red before disappearing.
Screen brightness threshold is significantly lower (not sure if it was intentional).
UPDATE: Seems to be intentional. Here's a quote from XDA explaining this:
"The first noteworthy feature is a changed brightness slider behaviour: It now changes the brightness logarithmic-ally instead of linearly. Before this preview when it was linear, about 90% of the brightness was controlled by the lower 20% of the left of the slider. The old 50% brightness was almost identical to 100% max brightness, and the old 5% brightness was significantly brighter than 0% brightness. Now, the change in perceptual brightness is more uniform as you increase or decrease the slider."
YouTube and some other apps aren't present in the App display in fullscreen list.
When using Fingerprint and face unlock the wake screen transition are noticeably slower.
Volume rocker primarily adjusts media volume over ringtone/notifications. (could be a feature of Android P) -
UPDATE: A feature of Android P
Ambient display doesn't show battery percentage.
Bluetooth connectivity issues with certain devices (works fine for me with bose and bullets wireless).
High Brightness in ambient display which may cause amoled burn.
UPDATE - September 10th
When covering proximity sensor, the finger print unlock does not work.
Fix - turn off pocket mode if you want to unlock device even after covering the proximity sensor.
Lift up display - emoji in display text gets its color distorted.
Navigation Bar sometimes fades in and out or disappears when the phone is unlocked by using Fingerprint sensor (unsure of the contributing triggers for this)
Alarm does not trigger in off mode even when the feature is available.
Schedule On/Off Phone sometimes doesn't turn on.
Hangout app is bugged - force closes when trying to send SMS.
Pattern lock is positioned at the center of the screen making it hard to swipe the pattern with your thumb.
Some Apps don't function/refresh properly when using Mobile Internet.
Works fine with WiFi though.
Adaptive brightness is horrible under direct sunlight (personal experience) - my screen may as well have been switched off. - will try a factory reset later to see if it fixes this.
Update - September 11th
When using this option, the recent apps menu (swipe up) gets bugged in a few ways (like clear apps button disappearing or card stacking etc.) - not sure if it's third party Launcher related or with the Oneplus Launcher or both.
Will edit this as we discover more bugs or if I have missed out on any existing ones.
NOTE:
Clearing Cache via Recovery(apparently does nothing) So read up on this quote from XDA
"In addition to the other changes, the cache partition has been removed. It now resides in the data partition and is no longer used for anything related to updates.
One result is that wiping cache in TWRP no longer does anything. If you want to clear cached data go into
Settings>Storage & memory, then tap Cached data at the bottom and then tap OK.
Try at your own risk.
Factory Reset seems to fix some of the issues - try at your own risk after taking a backup.
Here you go
@Funk Wizard
Do tag me(@aj2989) if you face any issues - which isn't on this list, and I will add it here after checking it out.
PS: I am not part of the staff, just taking note of common issues and putting it on a single post for everyones benefit. Please do not DM me to fix the issues.
Thanks for understanding
