276
OxygenOS Open Beta 2 for OnePlus 6
  1. Feroz_Mohammed
    Gingerbread Sep 11, 2018
    Feroz_Mohammed , Sep 11, 2018 :
    check YouTube
    Vladut123 likes this.
  2. darksavior21
    Froyo Sep 11, 2018
    darksavior21 , Sep 11, 2018 :
    How do I return to MP version. The one that downloaded from Open beat 1 post doesn't work. Can someone please guide me?
  3. Swan maity
    Donut Sep 11, 2018
    Swan maity , Sep 11, 2018 :
    guys there is a major problem with slow motion camera after updating pie beta 2. what should I do?
  4. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Sep 11, 2018
    KeepTransisting , Sep 11, 2018 :
    Either describe the problem or downgrade to stable
    Vladut123 and Aks41179 like this.
  5. rishabh382
    Cupcake Sep 11, 2018
  6. Swan maity
    Donut Sep 11, 2018
    when I start the slow motion recording camera started flickering and a black shadow infront of display occurred
    Vladut123 and rishabh382 like this.
  7. superjoyce
  8. aj2989
    Honeycomb Sep 11, 2018
    aj2989 , Sep 11, 2018 :
    If shooting indoors it will flicker as the refresh rate of the light source is at 60hz(60fps max before flicker) whereas the camera shoots at 480fps for slow motion, it won't flicker or appear dark when shot outdoors under decent sunlight.
    This is not a major problem. It's like saying the sun is too bright so it's bugged [e]1f602[/e]
    Vladut123 and KeepTransisting like this.
  9. KeepTransisting
    I mean, I do think the sun is bugged because it's too bright. We gotta dial that shit back a bit ;)
  10. aj2989
    The big guy up in the sky hasn't released an Ota for a while now.. Maybe we'll see one in another 2000 years? [e]1f601[/e]
  11. MarttiMikael
    Eclair Sep 11, 2018
    MarttiMikael , Sep 11, 2018 :
    will the beta path eventually lead to stable OTA update or do i have to downgrade back to oreo and join the stable path?
  12. aj2989
    It probably won't come through beta Ota. Maybe through oxygen updater but you would need to factory reset again.
    If you are in 5.11 then you can get the Ota without formatting, but you need to factory reset to roll back anyway.
    Vladut123 and MarttiMikael like this.
  13. thetonyclifton
    Froyo Sep 11, 2018
    thetonyclifton , Sep 11, 2018 :
    Can someone help me with version numbers please. I have been using an Android P beta for weeks now with no issue, build number is a6003_22_180714 can anyone tell me - is this the developer preview? Should I be updating to these open beta builds?
  14. N1536479578321
    superjoyce and Vladut123 like this.
  15. aymantkurdi
    Donut Sep 11, 2018
  16. PF Albertini
    Donut Sep 11, 2018
    PF Albertini , Sep 11, 2018 :
    Hello man, I think toi should describe precisely your issues with the camera ;)
  17. B_Wrath
    Nougat Sep 11, 2018
    B_Wrath , Sep 11, 2018 :
    Who said it's not working on beta... It's working perfectly...
    Tell exactly what is the problem you are facing..
    Vladut123 and otto2 like this.
  18. Nicauw
    Donut Sep 11, 2018
    Nicauw , Sep 11, 2018 :
    Bonjour,
    j'ai un oneplus6, et j'avais installé la bêta 1 d'Android P et j'étais assez étonné du très peu de bugs qu'il y avait, la version était très stable. Cependant, j'ai fais l'erreur de passer à la bêta 2, et là ;
    - une batterie qui ne tient plus la charge
    - mes notifications sont en roue libre ; je ne reçois pas toujours mes notifications Snaps, j'ai un problème avec mes notifications Messenger qui se sont transformées en notifications Facebook me redirigeant vers une mauvaise page, celle ci me disant d'utiliser l'application Messenger (que je possède bien sûr)
    - de nombreux crash d'applications, Messenger, Snapchat, 9gag, etc....
    - des problèmes pour télécharger des applications sur le play store, j'ai remarqué qu'en lançant un téléchargement, si je quittais l'application, celui-ci se stoppait. Ce qui n'est normalement pas le cas
    J'oublie sûrement d'autres problèmes que j'aurai pu constater, mais voilà, le but étant de remonter les soucis que j'ai rencontré et faire mon bon français en étant mécontent du fait que cette version soit moins stable que la première qui, je le répète, fonctionnait du feu de dieu.
    Bonne journée à vous.
  19. vriesdejoop
    Ice Cream Sandwich Sep 11, 2018
    vriesdejoop , Sep 11, 2018 :
    Nicauw
    Bonjour,
    please use English, as this is the English part of the forum, or go to the dedicated French forum part!
  20. Nicauw
    Donut Sep 11, 2018
    Sorry, I can't post anywhere on the application, when I try to start a thread I just have a pop up window where's said ; you don't have permission to do this. So I tried here
