276
OxygenOS Open Beta 2 for OnePlus 6
  1. Hugper
    Eclair Sep 11, 2018
    Hugper , Sep 11, 2018 :
    With what application?
    Vladut123 likes this.
  2. L1534863292512
    Cupcake Sep 11, 2018
    L1534863292512 , Sep 11, 2018 :
    when I am searching numbers direct from keypaid area ...that number will be hide from your blue color icon...it's my houmble request you to pls remove that blue colour or make that blue color size small so that will click from there
    look number and name not show so pls short this step in next update
  3. aj2989
    Honeycomb Sep 11, 2018
  4. Hareshvaan
  5. aj2989
    aj2989 , Sep 11, 2018 :
    You have to do it manually by going inside storage setting for whatever app you want to clear. I think P removed the clear cache together feature(used to be the in oreo) or maybe it's a bug. Someone has to confirm this.
  6. Hugper
    Eclair Sep 11, 2018
    Vladut123 and aj2989 like this.
  7. Sriharsha Koduru
    Gingerbread Sep 11, 2018
  8. PF Albertini
    Donut Sep 11, 2018
    PF Albertini , Sep 11, 2018 :
    Hello ! I think the Final release will launch at the end of september or in october ;)
  9. B_Wrath
    Nougat Sep 11, 2018
    B_Wrath , Sep 11, 2018 :
    He is a user just like you and me... He is just compiling the list of bugs..
    And it seems more like a problem with your GBoard and its suggestive algorithm... You can try clearing your typing pattern..
  10. aj2989
    it's next to each other, lol. I don't think that's a bug, but your finger or thumb is hitting it by mistake.
  11. krafiq
    krafiq , Sep 11, 2018 :
    After upgrading to open beta Android p certain apps are not working
  12. chazey2
    Jelly Bean Sep 11, 2018
    chazey2 , Sep 11, 2018 :
    Reboot and re install your app and try.
  13. Horizon21000
    Horizon21000 , Sep 11, 2018 :
    No there is not such an issue! Clear data of the app or make directly a factory reset.
  14. Pwalraven30
    Pwalraven30 , Sep 11, 2018 :
    The same answer as always, When it's ready !!
  15. MANYA_1999
    MANYA_1999 , Sep 11, 2018 :
    There is a reason why it is called beta.
    Report these bugs.
    Vladut123 and B_Wrath like this.
  16. aj2989
    When typos start become bugs [e]1f602[/e]
  17. PatrickNL
    PatrickNL , Sep 11, 2018 :
    sometimes I'm having the same issue, if you have that problem, go back to contacts, swipe up and it will work again
  18. Mikko_P
    Froyo Sep 11, 2018
    Mikko_P , Sep 11, 2018 :
    Screenshot_20180911-203256.jpg you can also Make backup with your Google account And restore from there.
  19. bvotje
    Froyo Sep 11, 2018
    bvotje , Sep 11, 2018 :
    I have just one problem with this beta no message light and charge light.
  20. Horizon21000
    This is not a question of what you want or not. The bugs you are experiencing won't be solved in future updates (because they not existing)! Something messed up your system state and now you need to do a factory reset to clean this state!
    Vladut123, otto2 and Mikko_P like this.
