276
OxygenOS Open Beta 2 for OnePlus 6
  1. aj2989
    Honeycomb Sep 11, 2018
    aj2989 , Sep 11, 2018 :
    Best I've seen since I put dual sim in. Used to get 6-6h30m on oreo.
    Vladut123 and Horizon21000 like this.
  2. chazey2
    Jelly Bean Sep 11, 2018
    chazey2 , Sep 11, 2018 :
    Then what's your problem, if you can't follow simple advice to fix the problem then you are part of the problem therefore in my eyes and probably others you have no problem. put up with it or follow advice your call. But you have no problem it's in your hands.
    Vladut123, Horizon21000 and Mikko_P like this.
  3. chazey2
    Please don't tell me there is an issue with shutting down a phone now!!! What next 'my OP6 didn't stop it raining' come on!
    Vladut123 likes this.
  4. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Sep 11, 2018
    KeepTransisting , Sep 11, 2018 :
    Cache doesn't exist anymore like it used to. You don't need to clear cache now.
    Vladut123 and Q1536008043944 like this.
  5. Tonhocruz
    Froyo Sep 11, 2018
    Tonhocruz , Sep 11, 2018 :
    Fingerprint unlocking is slower when used right after closing shutting down screen
  6. scorpio41
    Donut Sep 11, 2018
    scorpio41 , Sep 11, 2018 :
    yo me esperare a la version final de android pie, creo es lo mejor, pero gracias a las personas que pueban las betas, por ellos tenemos el mejor dispositivo del mundo
  7. saivedavyas
    Eclair Sep 11, 2018
    saivedavyas , Sep 11, 2018 :
    how to clear the cache there is no option for that in storage and memory
  8. KeepTransisting
    You can only do it from the third party TWRP recovery. And it also does nothing, pretty much.
    saivedavyas and Vladut123 like this.
  9. ger_aloysius
    Donut Sep 11, 2018
    ger_aloysius , Sep 11, 2018 :
    if i install this open beta 2 rom to my oneplus, when the beta is done and oneplus is finally launch the stable Android P Oxygen OS, should i flash again the new rom or i will get the update as OTA at my rom as the beta one ?
  10. Hugper
    Eclair Sep 11, 2018
    Hugper , Sep 11, 2018 :
    just wondering if I could fix it without wiping my data.
  11. nkh1206
    Donut Sep 11, 2018
    nkh1206 , Sep 11, 2018 :
    You will have to flash the stable ROM or you will continue to be on the Open Beta Platform.
  12. mitchelv07
    Froyo Sep 11, 2018
    mitchelv07 , Sep 11, 2018 :
    Hi guys,
    I currently have a rooted OnePlus 6, with Android 8.1. Lets say 9 is officially out, what is the procedure to install Android 9 on the OnePlus 6 with TWRP enabled? I'm aware that i will lose all my data.
  13. Pt25
    Eclair Sep 11, 2018
    Pt25 , Sep 11, 2018 :
    I'm not getting insta direct notification! after i updated Beta 2
  14. manie329
    Donut Sep 11, 2018
    manie329 , Sep 11, 2018 :
    what's the name of the launcher in this photo?
  15. E1536694997562
    Cupcake Sep 11, 2018
  16. Kostas-7
    Froyo Sep 11, 2018
    Vladut123 and SanDaDdiO like this.
  17. SanDaDdiO
    Eclair Sep 11, 2018
  18. Kloudy123
    Donut Sep 11, 2018
    Kloudy123 , Sep 11, 2018 :
    I have also noticed another thing, nor sure if it is a glitch or a bug but my wallpaper seems to go back to the default one every now and then.
  19. gubro
    KitKat Sep 11, 2018
    gubro , Sep 11, 2018 :
    Full reset your phone.
  20. Kostas-7
    Froyo Sep 11, 2018
