276
OxygenOS Open Beta 2 for OnePlus 6
  1. E1536694997562
    Cupcake Sep 11, 2018
    Vladut123 likes this.
  2. Kostas-7
    Froyo Sep 11, 2018
  3. Kostas-7
    Froyo Sep 11, 2018
  4. gubro
    KitKat Sep 11, 2018
  5. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Sep 11, 2018
    Vladut123 and otto2 like this.
  6. TonioLA
    Ice Cream Sandwich Sep 11, 2018
    TonioLA , Sep 11, 2018 :
    finally I moved back to stable one.
    I love the new UI but I think that the split screen is easier to put in place with old UI.
    otherwise all was ok
  7. manishraj.abhi@g
  8. darksavior21
    Froyo Sep 11, 2018
    darksavior21 , Sep 11, 2018 :
    I am trying to move to stable. But can't see to make it work. Here is what I have done, I went to Beta 1 post and downloaded MP version. When I went to local upgrade in the settings, it's not allowing me to flash it. Can you guide me steps to move to MP.
  9. TonioLA
    move the zip file to the root of the phone. just cut and paste it
  10. darksavior21
    Froyo Sep 11, 2018
    Tried that already. Here is the error that I am getting:
  11. chazey2
    Jelly Bean Sep 11, 2018
    chazey2 , Sep 11, 2018 :
    If you have USB OTG it's simple and I can help. Do you have OTG USB?
  12. hrbrtalln
    hrbrtalln , Sep 11, 2018 :
    I have been having issues with the stability of my network signal and data connectivity.
    Default preferred type is always wcdma. Before the beta I am getting LTE/CDMA/UMTS Auto.
    Also the multitask isn't functioning well
  13. SanDaDdiO
    Eclair Sep 11, 2018
    SanDaDdiO , Sep 11, 2018 :
    wondering if there is a way to get games back to full screen after beta2 install. it was working just fine on ota but now the game mode has taken the games out of full screen apps list and not able to get them back to full screen. any help is appreciated.
  14. x8xx8x
    Honeycomb Sep 11, 2018
    x8xx8x , Sep 11, 2018 :
  15. Nounousss971
    Nounousss971 , Sep 11, 2018 :
    After installing Android update pie, there are no more images on the channels of the application MyCanal. There is only sound and no picture. Can you give me a solution please. Thank you.
  16. K1531925598076
    Eclair Sep 12, 2018
    K1531925598076 , Sep 12, 2018 :
    I would like too add, positive things that fixed my Oneplus 6 Infinity War Edition.
    1. My GPS is now working
    ...That is all
    previously, my gps could not get any fix. Thus, using waze or Google Maps is a pain in the butt. Now it is fix, i am happy. Keep up with the good work, and try to maintain the coding for GPS, eventho i have no idea what it is about coding, but what you did, definitely helps my GPS now. Now i am 100% satisfied and happy with my Oneplus 6.
  17. G_Ramakrishna_Reddy_EfmN
    Donut Sep 12, 2018
  18. FaleshC
    KitKat Sep 12, 2018
    LegolasX and Vladut123 like this.
  19. C1527306436682
    Donut Sep 12, 2018
    C1527306436682 , Sep 12, 2018 :
    SEPTEMBER 12TH
    ISSUE:-
    1. Half of the apps closes automatically (like force closed).
    2. Navigation Gestures:- Home and back button option isn't working properly. It stucks when moving from one app to another by just sliding.
    SEPTEMBER 13TH
    ISSUE:- Reading Mode.
    Today i faced this reading mode issue. Using default launcher i tried to open Amazon Kindle app (which ia set for reading mode). After a while if i closes the app. The Colors of screen aren't back to normal. Reading mode is still on. Either i have to restart the device or go to display settings and Screen calibration to default.
    I thought it's one time error but I tried with other reading apps too. Before Open Beta 2 everything with reading mode was fine.
    Please reply if anyone else faces the same issue or it's just my device messed up after the Open Beta2 upgrade.
  20. G_Ramakrishna_Reddy_EfmN
    Donut Sep 12, 2018
