276
OxygenOS Open Beta 2 for OnePlus 6
  1. G_Karothikeyan
    Ice Cream Sandwich Sep 12, 2018
    Vladut123 likes this.
  2. B_Wrath
    Marshmallow Sep 12, 2018
    B_Wrath , Sep 12, 2018 :
    H1536132229407
    lot of problems in my mobile system after flashing BETA P 9 version, some time Volume get automatically down ttl go on silent mode automatically, any apps get open automatically, behaving like anything. pls fix it at the earliest.
    or pls advise..how to download older version ?​
    Read the open beta 1 thread.. Main post..
  3. B_Wrath
    It's a beta!!! It's supposed to have issues!!
    Do factory reset.. If will help... But backup your data first as factory reset will wipe your phone..
    Vladut123 and anilchelli like this.
  4. H1528826963641
    Donut Sep 12, 2018
    Vladut123 and F1536011049830 like this.
  5. shrmagarv
    Eclair Sep 12, 2018
    shrmagarv , Sep 12, 2018 :
    1. The volume key press manages volume for media only.
    2. While using app lock, If a notification come for the locked app, touching on the notification opens the app lock page even before the notification faded away.
    3. The contact image during the calling screen is cropped from the top around ⅓ of it.
    please someone register the bugs for these. I am unable to do so.
    thanks in advance.
  6. shrmagarv
    Eclair Sep 12, 2018
    one more:
    while going to recents the previous app should come in highlight(front) and the current app should go to extreme right (as shown in the image) but it shows the current app in front.
  7. FaleshC
    KitKat Sep 12, 2018
    FaleshC , Sep 12, 2018 :
    really? it's always current app in front.
    it's Pie don't compare it will older versions.
    LegolasX, Vladut123 and shrmagarv like this.
  8. jonathanmartinlara
    Donut Sep 12, 2018
    jonathanmartinlara , Sep 12, 2018 :
    When i ajust the volume for my alarm, the phone begins to play a alarm. And its waking up My family, can you fix it in next update
  9. shrmagarv
    Eclair Sep 12, 2018
    Don't you think I would more convenient if it happens this way. After all oxygen os is all about enhancements in stock android.
  10. FaleshC
    KitKat Sep 12, 2018
    actually it's more convenient when current app is in middle. it's feels natural.
  11. shrmagarv
    Eclair Sep 12, 2018
    FaleshC
    actually it's more convenient when current app is in middle. it's feels natural.​
    Actually, you are right It feels natural.
    But generally we go to recents to use another app or to swich to previous app. So It would be more convenient if the previous app come in front.
    can you please report bugs for my previous comment. ??
  12. smns.srinivas
    Eclair Sep 12, 2018
    smns.srinivas , Sep 12, 2018 :
    did anyone noticed... battery percentage not showing in ambient display locked screen
    is this my mobile prob or all have that ?
  13. FaleshC
    KitKat Sep 12, 2018
    it would only involve adding extra animations and transitions. the current app should animate to right and previous app should animate to center, looks complicated to me.
    and we have to swipe anyways, so doesn't make sense.
    LegolasX and Vladut123 like this.
  14. smns.srinivas
    Eclair Sep 12, 2018
    may be a app is doing that... I too had .. MobiKwik discharged my battery... os reported that and I uninstalled it ... now everything is fine...find urs..
  15. Horizon21000
    Honeycomb Sep 12, 2018
    Horizon21000 , Sep 12, 2018 :
    No, there is no battery drain in Beta 2! Same amazing battery life like in Beta 1.
    You should wait 2-3 full battery cycles. If you still have a battery drain, make a factory reset!
  16. Horizon21000
    You have the issues because you haven't done a clean flash!
    Do a factory reset and the issues will be solved!
  17. Horizon21000
    Before you report bugs, please do a factory reset!
  18. Horizon21000
    Do a factory reset and your issues will be solved!
  19. TonioLA
    TonioLA , Sep 12, 2018 :
    try to download the right zip. take the one from the post beta 1 on the forum. the file to downgrade is a special one
  20. Michael0210
    Cupcake Sep 12, 2018
