275
OxygenOS Open Beta 2 for OnePlus 6
  1. K1535125990312 Charliexop
    Froyo Sep 12, 2018
    K1535125990312 Charliexop , Sep 12, 2018 :
    I havent(and wont) instal beta version,but from what i saw on you tube,there isnt much of a difference in android P- just a few small visual changes(but its the same with every update,had androids from 2.0 to 8.0 android versions).The only and main question is how it performes on 9.0 but i have no doubt OP will perform great in every version.
    Vladut123 likes this.
  2. L1536149155213
    Cupcake Sep 12, 2018
  3. Heiko87
    Eclair Sep 12, 2018
    Heiko87 , Sep 12, 2018 :
    can you please made the display brighter?
    in the sun I can't look good :-( I read on some websites there is a high brightness mode on rootet device's
    but i don't want root my phone for I have no xp with rooting and don't want **** up my phone.
  4. Harkamal_Atwal
    Donut Sep 12, 2018
    Harkamal_Atwal , Sep 12, 2018 :
    it has been a month since i have not recieved any notification on some apps like Instagram,Snapchat and many more.Even the notifications are enabled from the settings.
    even if any message comes it does not notify and only appears when app is opened.
  5. Vinay_NS
    Gingerbread Sep 12, 2018
    Vinay_NS , Sep 12, 2018 :
    in settings.. go to battery optimization and remove these apps from being optimized..
  6. G_Abdul_Basith_TMMS
    Eclair Sep 12, 2018
  7. Horizon21000
    Honeycomb Sep 12, 2018
    Horizon21000 , Sep 12, 2018 :
    Most of the issues are only there because you guys haven't made a factory reset!
    Perform a factory reset and you will see that Beta 2 is pretty stable and bugfree!
  8. Harkamal_Atwal
    Donut Sep 12, 2018
  9. G_Abdul_Basith_TMMS
    Eclair Sep 12, 2018
    G_Abdul_Basith_TMMS , Sep 12, 2018 :
    when some one calls I am not getting any calling option when the phone is locked ??
    finding difficult to use pls support
  10. Balaji Murali
    Donut Sep 12, 2018
    Balaji Murali , Sep 12, 2018 :
    amazing performance on the phone and feels really fast. keep up the good work and keep making the performance blazingly fast.
  11. alexferdean
    Ice Cream Sandwich Sep 12, 2018
    alexferdean , Sep 12, 2018 :
    I keep my display on DCI-P3 but many times I find that it switches to default by itself. Maybe after exiting night mode, I don't know for sure.
  12. H1536132229407
    Donut Sep 12, 2018
    H1536132229407 , Sep 12, 2018 :
    may be reading mode is activated, deactivate it and try
  13. Tamukanashe Musengezi
    Tamukanashe Musengezi , Sep 12, 2018 :
    for 2 use OnePlus launcher not 3rd party
  14. Chetan.mishra
    Donut Sep 12, 2018
    Chetan.mishra , Sep 12, 2018 :
    I was using the Beta and now running Beta 2 without doing a factory reset, so far have not come across any major bug, and using this as my daily driver without any issues.
    P.S.: 1. I do not play any games on my OP6
    2. Have already reported a couple of bugs in the feedback section and have received satisfactory response so far...
  15. Tamukanashe Musengezi
    1.they will not add it they said as much at the launch.
    report to feedback
  16. X1511694316526
  17. alexferdean
    No, I almost never use reading mode. I use auto night mode, this might be the one thing that might trigger this bug.
  18. Sudhanshu Joshi SDD
    Sudhanshu Joshi SDD , Sep 12, 2018 :
    there are lots of changes, just don't look for ui changes
  19. aj2989
    aj2989 , Sep 12, 2018 :
    So today I tried to take a back up of my media folder, and when I plugged in the OP6 to my pc; it didn't get detected. So I enabled USB Debugging and switched to file transfer, but only the "OnePlus Drivers icon" show up and my a6000 folder doesn't (was working fine on Oreo). I've tried to reinstall drivers after manually deleting it from device manager under ADB interface but the drivers setup is stuck at "Execute the commands". I've tried unplugging and replugging, restarting PC and all sorts of troubleshooting but it just doesn't install the drivers. Anyone else facing this problem? Does anyone know a fix for this?
  20. FaleshC
    KitKat Sep 12, 2018
    FaleshC , Sep 12, 2018 :
    remove old drivers and copy the content of the OnePlus drivers to PC. Disconnect Phone and install the drivers.
