276
OxygenOS Open Beta 2 for OnePlus 6
  1. aj2989
    Honeycomb Sep 12, 2018
    aj2989 , Sep 12, 2018 :
    Nope, didn't work. Again its still stuck at "Execute the commands..." progress bar at full. I will leave it on for 30mins and check again.
    Vladut123 likes this.
  2. FaleshC
    KitKat Sep 12, 2018
    FaleshC , Sep 12, 2018 :
    it will be there forever. i have tried already.
    Did you copy the contents to PC?
    and removed all oneplus drivers.
    check if it is detected in Device Manager. if there remove from there also.
    then reboot
    LegolasX and Vladut123 like this.
  3. aj2989
    Deleted under ADB interface in device manager, Uninstalled using programs and settings option, restarted PC, Copied the contents and tried installing when unplugged and tethered but still the same progress bar issue. PTP works though, just not USB debugging or File transfer (PC makes the detection sound though)
  4. jyothi_GVB
    Cupcake Sep 12, 2018
  5. FaleshC
    KitKat Sep 12, 2018
    Did you check cable?
    If cable is fine, the drivers are messed up.
    for me i used to have this exact issue with Oneplus X. Removing phone and installing drivers always did trick.
  6. El_Baptisto
    Froyo Sep 12, 2018
    El_Baptisto , Sep 12, 2018 :
    I haven't the new multitask panel and the new navigation bar doesn't work for me... It stay at the old oreo's navbar even if I activate the new navbar in settings... Have you reported these bugs?
  7. FaleshC
    KitKat Sep 12, 2018
    Two Words
    Factory Reset!!
  8. Suri_395
    Eclair Sep 12, 2018
    Suri_395 , Sep 12, 2018 :
    I too facing the same problem and provide any feedback for that issue as for 64gb varient it's an important to have clear some data
  9. Valentindra
    Froyo Sep 12, 2018
  10. shrmagarv
    Eclair Sep 12, 2018
    shrmagarv , Sep 12, 2018 :
    Conference call also doen't seem to connect in Open beta 2.
    Any one else is also facing this issue??
  11. G_kirigeri_sk_pavan_iUwa
    Eclair Sep 12, 2018
    Vladut123 and F1536011049830 like this.
  12. Kapil.ranjan
    Eclair Sep 12, 2018
  13. shrirajputIN
    Eclair Sep 12, 2018
    shrirajputIN , Sep 12, 2018 :
    Screen on Time reduced to 4.5 hrs from 5.5 hrs
    hope this will be fixed in next beta update
  14. shrirajputIN
    Eclair Sep 12, 2018
    can you post user battery usage data
    just for information
  15. W1536743125769
    Vladut123 and pablo20520 like this.
  16. Kapil.ranjan
    Eclair Sep 12, 2018
  17. El_Baptisto
    Froyo Sep 12, 2018
    I fix the issue (oneplus launcher was in 2.5.1 and not on 3.0.0, I just updated it with the correct apk)
  18. KITTU369SIRI
  19. FaleshC
    KitKat Sep 12, 2018
    Bingo!!!
  20. aj2989
    Yes, the ADB drivers were messed up. I downloaded the ADB drivers again and uninstalled all drivers related to OP6 and then I restarted PC. Once it restarted, I went inside device manager and under the Other Devices Tab - Unknown Device, I right clicked it and then hit update driver software > browse my computer > let me pick from list of devices on my computer> MTP USB device and hit OK. This worked for me.
    Vladut123 and B_Wrath like this.
