276
OxygenOS Open Beta 2 for OnePlus 6
  1. pmoar3
    Froyo Sep 12, 2018
    pmoar3 , Sep 12, 2018 :
    Anyone noticed? Last app switch doesn't work with custom launcher. Anyone have idea about of this can be solved
    Vladut123 likes this.
  2. thiccramen
    Froyo Sep 12, 2018
    thiccramen , Sep 12, 2018 :
    this has been an issue in all betas as the recents screen seems to be part of the oneplus launcher itself. wait for the stable release
  3. siamer
    Gingerbread Sep 12, 2018
    siamer , Sep 12, 2018 :
    i see problem with brightness sensor. after unlocking brightness is set to max for few sec android then adjust to auto even in dark room...
  4. raj19293
    Cupcake Sep 12, 2018
  5. Lunatico
    Jelly Bean Sep 12, 2018
    Lunatico , Sep 12, 2018 :
    @aj2989 Hello. I've encountered a big that happens pretty often and it has to do with the on screen buttons....they keep disappearing but they seem to come back after seconds later or when I swipe page on the home screens.
  6. zoran81
    zoran81 , Sep 12, 2018 :
    Really?!?
    Vladut123 and Predict23 like this.
  7. ming3r
    Froyo Sep 12, 2018
    ming3r , Sep 12, 2018 :
    Yup really.
    Built in updater says it won't flash an older zip to prevent bootloops.
    Recovery doesn't have options to flash from zip or ADB Sideload anymore.
  8. ade0410
    Ice Cream Sandwich Sep 12, 2018
    ade0410 , Sep 12, 2018 :
    then you're knackered!
    you knew the risk of installing a beta.
  9. raiderx303
    Eclair Sep 12, 2018
  10. niididdy
    Eclair Sep 12, 2018
    niididdy , Sep 12, 2018 :
    I did. I just found out everyone who uses the Samsung iPOLiS Application has the same issue on Android 9. I also got with their technical support via email.
  11. sagnik9
    sagnik9 , Sep 12, 2018 :
    After updating to Open Beta 2 not being able to cast to Google home mini. Anyone else facing this issue?
  12. kulek79
    Donut Sep 12, 2018
    raiderx303 and Vladut123 like this.
  13. Gary S
    Froyo Sep 12, 2018
    Gary S , Sep 12, 2018 :
    No. I am casting to my Google home mini from Play Music right now
  14. ming3r
    Froyo Sep 12, 2018
  15. H1J4CK3D
    H1J4CK3D , Sep 12, 2018 :
    beta 2 is heaps faster then beta 1. Perhaps they need to increase the brightness but like beta 2 so far
  16. PavJhita
    Froyo Sep 12, 2018
    PavJhita , Sep 12, 2018 :
    Does anyone else not receive push notifications from third party apps such as WhatsApp?
  17. H1J4CK3D
    no, I'm receiving mine
  18. NerdicEclipse
    Honeycomb Sep 12, 2018
    NerdicEclipse , Sep 12, 2018 :
    ming3r
    Looks like you can't revert to OB1 or the last stable Oreo.
    You absolutely can go back to stable Oreo, but not Beta 1. Instructions in first post of original beta thread. Jesus what is it with you people and reading.
  19. ming3r
    Froyo Sep 12, 2018
    Do you not see the file I have in my screenshot? that's 5.1.11. Thanks for being helpful.
  20. NerdicEclipse
    I did. You're welcome. Instructions and file necessary are linked in the first post of the original beta thread. Just downgraded myself an hour ago.
    It's really not difficult if one has the intelligence of a rock or higher. This crap gets posted over and over and over again and they explained it VERY clearly.
