276
OxygenOS Open Beta 2 for OnePlus 6
  1. devoncatt
    Gingerbread Sep 13, 2018
    Vladut123 likes this.
  2. lutti
    KitKat Sep 13, 2018
    lutti , Sep 13, 2018 :
    So is it ready yet or is there still need for major fixes before they can launch it as an official OTA update?
  3. devoncatt
    devoncatt , Sep 13, 2018 :
    Since many people are asking how to go back to stable Oreo from the beta
    From a post on XDA developers
    Please note:
    If you have already flashed an Open Beta (you are currently running the latest Open Beta) you will receive this new build as an OTA.
    If you are not running open beta software and would like to, please refer to the flashing instructions and the full ROM found on the downloads page here: http://downloads.oneplus.com/ (requires full data wipe before updating from stable to open beta).
    Once you migrate to the Beta path, you will continue to receive Open Beta OTAs. You will no longer receive the regular Official Stable OTAs.
    Moving back to the Official OTA path from the Beta path will require a full install and clean flash (full wipe of all data and cache).
    Make sure to let us know how you feel about the beta builds here in the thread too, we are watching.
    Vladut123 and aj2989 like this.
  4. Kryptoxic
    Donut Sep 13, 2018
    Kryptoxic , Sep 13, 2018 :
    Been running the Open Beta for a few days now and so far so good. Battery life's pretty good so adaptive battery's working pretty well. One improvement to consider would be to change the vibration pattern of incoming SMSes because the vibration is literally two short and light vibrations.
  5. shrmagarv
    Eclair Sep 13, 2018
  6. Predict23
    Ice Cream Sandwich Sep 13, 2018
    Predict23 , Sep 13, 2018 :
    I noticed calls sometimes labeled with "HD" on the caller screen, anyone has any idea what is it exactly?
  7. Brownz
    Honeycomb Sep 13, 2018
    Brownz , Sep 13, 2018 :
    How to I downgrade it back to stable oxygen as can't download apps at all
  8. Riztnack
    Eclair Sep 13, 2018
    Riztnack , Sep 13, 2018 :
    Is the Android Pie Developer preview 3 better or worse than the oxygen beta 2?
    Is APDP 3 more along stock android?
  9. aj2989
    aj2989 , Sep 13, 2018 :
    Delete the cache of the games which are crashing or re-install them and try again. If you've tried this also and it's still creating problems, then perform a factory reset - after taking a backup. I will add it to the list of known issues if others are having the same problem as yours.
  10. arnav_89
    Froyo Sep 13, 2018
    arnav_89 , Sep 13, 2018 :
    This could be due to both parties having volte capable phones.
    Vladut123 and Predict23 like this.
  11. ade0410
    ade0410 , Sep 13, 2018 :
    Brownz
    How to I downgrade it back to stable oxygen as can't download apps at all​
    are you taking the mick?! someone took time to post this a few posts back!!
  12. tortoise14
    tortoise14 , Sep 13, 2018 :
    S
    See few posts above
  13. Brownz
    Vladut123 and tortoise14 like this.
  14. Brownz
    Any need for that language....
  15. aj2989
    @Funk Wizard maybe you should sticky this too?
  16. ade0410
    sorry to offend. I've edited my post!
  17. Brownz
    Do you know what I've done wrong as trying to get back to stable version but keeps coming up with this
  18. tortoise14
  19. tortoise14
  20. Brownz
