276
OxygenOS Open Beta 2 for OnePlus 6
  1. X1536841623717
    Eclair Sep 14, 2018
    X1536841623717 , Sep 14, 2018 :
    idk why but the phone has a lot of delay for unlocking be it through fingerprint or face scan this really bothers me please try to fix that
    Vladut123 likes this.
  2. G_Karothikeyan
    Ice Cream Sandwich Sep 14, 2018
  3. gubro
    KitKat Sep 14, 2018
    gubro , Sep 14, 2018 :
    Read the opening post of this thread.
  4. gubro
    KitKat Sep 14, 2018
    User error , need to learn to search and read.
    Vladut123 and Artemus. like this.
  5. wbgrunn
    Gingerbread Sep 14, 2018
    wbgrunn , Sep 14, 2018 :
    Before you switch back you may wanna try a factory reset from recovery. This will often fix alot of problems when dirty flashing.
    Oneplus Switch stores the backup file in your root within a folder called Backup.
    When you switch to another ROM, and you dont wipe internal storage (cache en system settings are fine) you will keep the backup.
    You can copy the Backup folder to your pc just to be sure. In that way you will always have control over a backup.
  6. G_bar_shaoni_wYbD
    Cupcake Sep 14, 2018
  7. X1536841623717
    Eclair Sep 14, 2018
    downgraded to the normal MV because this had a lot of issues.
    I'll just wait for the official update
    Vladut123 and Hardeep140301 like this.
  8. Hugper
    Eclair Sep 14, 2018
    Hugper , Sep 14, 2018 :
    thanks a lot
    Vladut123 and wbgrunn like this.
  9. Pankkajarora
    Pankkajarora , Sep 14, 2018 :
    possible bug - lower menu option doesn't appear when used Chromecast
    steps to reproduce:
    1. cast YouTube via Google Chromecast
    2. let the screen remain idle and get it locked it's own
    3. now unlock the phone lower menu buttons back, menu, app explorer are not visible.
    to solve this
    lock & unlock the phone, problem resolved.
  10. Anirudh Gursal
    Eclair Sep 14, 2018
    Anirudh Gursal , Sep 14, 2018 :
    the only thing I found out buggy is auto brightness and would love to see always on display in open beta 3 also the option to change ringer,media and alarm volume rather than going all the way to settings
  11. JAGADISH BHATTA
    Jelly Bean Sep 14, 2018
    JAGADISH BHATTA , Sep 14, 2018 :
    Support>Bug reports
  12. naveenaradya
    naveenaradya , Sep 14, 2018 :
    hello guys, i am facing a battery issue.My phone battery drains upto 10% at night what is the solution for it
    what is the solution? please help.
  13. Atiq1989
    Froyo Sep 14, 2018
  14. N1508652287651
    N1508652287651 , Sep 14, 2018 :
    Hi
    please help me Android P can't update device. follow instruction -System update -top corner-locsl update - can't see file .....
    How update Android P
  15. SoniaB
    Nougat Head Moderator Sep 14, 2018
    SoniaB , Sep 14, 2018 :
    Thread merged with main release thread. Please seek assistance here.
    Did you follow the instructions correctly? Downloaded the zip file, transferred it to your root storage and then continued via System update and local upgrade?
    Vladut123 and Sun90 like this.
  16. Mr. Vandelay
    Mr. Vandelay , Sep 14, 2018 :
    If you are trying to flash OB2 read this
  17. Anirudh Gursal
    Eclair Sep 14, 2018
  18. VIVENZO2010
    Eclair Sep 14, 2018
    VIVENZO2010 , Sep 14, 2018 :
    Great work with the update, but I've experienced 2 bugs in addition to the yellow texts on the ambiant display.
    - When I change the SMS ringtone to any sound I want it shows it's changed, but when I receive an SMS or MMS it rings the default notification sound.
    - When inside an app for example: Facebook, or maps and the display has timed out after sometime of inactivity or while in the app I happen to press the power button to lock the phone and then unlock it, the nav bar and the status bar will disappear. It doesn't happen every single time but quite often
  19. Z1535420745552
  20. sblantipodi
    Honeycomb Sep 14, 2018
