275
OxygenOS Open Beta 2 for OnePlus 6
  1. T1530626694637
    Eclair Sep 15, 2018
    T1530626694637 , Sep 15, 2018 :
    you can turn it off from automatic wifi connection
    Vladut123 likes this.
  2. F_Ram_Reddy_gQCF
    Donut Sep 15, 2018
    F_Ram_Reddy_gQCF , Sep 15, 2018 :
    yes I know that and it can be done in that way also , here I am just posting issue with the software.
  3. F_Ram_Reddy_gQCF
    Donut Sep 15, 2018
    F_Ram_Reddy_gQCF
    yes I know that and it can be done in that way also , here I am just posting issue with the software.​
    my issue is for not with single wifi connection. I am facing issue with wifi itself.
  4. T1530626694637
    Eclair Sep 15, 2018
    actually that's not the issue they're just giving a Better connectivity options
  5. T1530626694637
    Eclair Sep 15, 2018
    oh... lets see they'll fix it soon
    Vladut123 and F_Ram_Reddy_gQCF like this.
  6. G_Karothikeyan
    Honeycomb Sep 15, 2018
    G_Karothikeyan , Sep 15, 2018 :
    I am also experienced with this bug......
  7. K1532105269195
    Donut Sep 15, 2018
  8. F_Rakesh_Roshan_Rana_QCK
    F_Rakesh_Roshan_Rana_QCK , Sep 15, 2018 :
    Just go to setting and allow notification access to caller/ phone app... I had same issue but sorted...
  9. F_Rakesh_Roshan_Rana_QCK
  10. imsagar19
    Cupcake Sep 15, 2018
  11. BhavyaMehta0786
    Ice Cream Sandwich Sep 15, 2018
    BhavyaMehta0786 , Sep 15, 2018 :
    try enabling dual 4g in the sim settings and also tap on the second sim there and enable Volte
  12. Tclarke-94
    Gingerbread Sep 15, 2018
    Tclarke-94 , Sep 15, 2018 :
    I think picture quality is good but video quality is really bad
  13. ateeque2000
  14. SCHINDLERs
    Donut Sep 15, 2018
    SCHINDLERs , Sep 15, 2018 :
    my version and all of the apps I tried are running without any problems :) good work! how is it working after the beta test period? Are we get automatically the pie 9.0 by OTA?
  15. Khamar_naick
    Khamar_naick , Sep 15, 2018 :
    how did you do it can you explain me
  16. MUDIRD
    Donut Sep 15, 2018
    MUDIRD , Sep 15, 2018 :
    default message app is very slow, specially the updates section is taking lot of time to load.
    after trying multiple times, it came to normal and stated responding fast.
    but on getting new messages like OTP and updates, again it getting slow.
  17. B1523422503106
    B1523422503106 , Sep 15, 2018 :
    frequently speaking I had to gone to one plus centre for downgrade :/
    Vladut123 and Khamar_naick like this.
  18. MUDIRD
    Donut Sep 15, 2018
    I am facing heating problem, initially it was reported by one of the app "Bajaj Finserve", I killed it and then uninstalled from phone.
    I shutdown my phone and then kept for charging, after a while when it reached 70%, again I turned it on, but still I am facing heating issue .
  19. Khamar_naick
    did you tried doing it on your own
  20. B1523422503106
    yes I did but I failed and according to oneplus there would be a issue of warranty void if you do it wrongly so had to visit centre ..
