136
OxygenOS Open Beta 2 for the OnePlus Nord
  1. rajbgp
    Gingerbread Jan 25, 2021
  2. Topper_Gas
    KitKat Jan 25, 2021
    Topper_Gas , Jan 25, 2021 :
    I've also just updated to the Beta 2 (EU) and I'm not facing any mobile data issues, it's most likely nothing to do directly with the Beta 2 update, and so just downgrading to Beta 1 may well have not resolved the issue.
  3. _l_black
    Cupcake Jan 25, 2021
    _l_black , via OnePlus Nord , Jan 25, 2021 :
    Looks like the update maked the screen more green then before when playing with brightness
    But boot screen is color clean so the problem isn't in the screen itself
  4. Soumya Roy
    Soumya Roy , Jan 25, 2021 :
    1611608531821.jpg said:
    Why we don't get those amazing Oxygen OS 11 live wallpapers came with OnePlus 8T...? I loved those... I installed those on my Nord but doesn't work as fluid as stock ones... Really want at least one in stable release...
    satti8893 likes this.
  5. Mohammed Shakeel Shaikh , via OnePlus Nord , Jan 25, 2021 :
    Hey thanks for the update. But since the day I have installed the beta I am not able to add my face data for face unlock feature. I was using the face unlock feature on stable Oxygen OS 10. But due to some reason I had deleted the face data a few days before I installed beta. Kindly guide me.
  6. D1609974524465
  7. D1609974524465
  8. Migl0n
    Eclair Jan 25, 2021
    Migl0n , via OnePlus Nord , Jan 25, 2021 :
    Nice work with this beta, seems really stable!
    Any chance of having 5g network available with carrier Yoigo in Spain? Currently it's only available for Movistar or Vodafone with Overplus Nord
  9. P1605140689999
    Cupcake Jan 26, 2021
  10. K1610217447066
  11. KoalaOnDrugs
  12. KoalaOnDrugs
  13. ashishlp007
    Ice Cream Sandwich Jan 26, 2021
    ashishlp007 , via OnePlus Nord , Jan 26, 2021 :
    You are on stable version of os 10. If you want os11 beta update then download it from the below link:
    https://forums.oneplus.com/threads/oxygenos-open-beta-1-for-the-oneplus-nord.1373403/ said:
    Full instructions are given. Read them carefully.
    Once you downloaded and installed the open beta 1 update on your device, you will automatically get the open beta 2 update via OTA from settings.
    Remember... to get the stable OTA for os11, you will have to downgrade your device from open beta 2 to 10.5.10 update which will erase all your data. Its your choice now.
    If you are sure you can do it without any mess then please go ahead or else just wait for the stable os11 update.
    Its coming soon.
  14. lonewolfe_01
    lonewolfe_01 , via OnePlus Nord , Jan 26, 2021 :
    Yeah, that's my problem it doesn't in my pc after updating my phone to android 11, previously it used to work fine just as you told!
  15. ashishlp007
    If you are on 10.5.10 version, then you have to download and install the open beta update for os11 from the below link
    If you are already on open beta 1 then wait... you will automatically get the open beta 2 update via OTA else you can download Oxygen Updater from playstore and download open beta 2 update.
  16. J1599181707259
    Eclair Jan 26, 2021
    J1599181707259 , via OnePlus Nord , Jan 26, 2021 :
    You have to work on some other issues as well like
    1. Battery drain
    2. Network Connectivity
    3. Font size
    4. Lagging while switching app
    5. Notification delay
    6. Colour shift from gray to black and vice-versa
    7. Gallery loading time
    8. File manager file sorting
  17. D1600515566323
    D1600515566323 , via OnePlus Nord , Jan 26, 2021 :
    Bro I am installing oxygen is 11
