165
OxygenOS Open Beta 20/11 for OnePlus 3/3T
Thread Status:
Not open for further replies.
  1. Petjitsu
    KitKat Jul 31, 2017
    xcrm and mariogold42 like this.
  2. Nawanga
    Cupcake Jul 31, 2017
  3. Petjitsu
    KitKat Jul 31, 2017
    Predict23, varma246, zoran81 and 3 others like this.
  4. zoestar
    Lollipop Jul 31, 2017
    adpro, Sun90, varma246 and 3 others like this.
  5. Bobbie63
    Marshmallow Jul 31, 2017
    Bobbie63 , Jul 31, 2017 :
    Well at least @Adam was seen March 13th, 2014. Guess he doesn't care about the security patch
    Android450, Sun90, varma246 and 3 others like this.
  6. F_Vi_Singh_YvLM
    Donut Jul 31, 2017
  7. zoran81
    Jelly Bean Jul 31, 2017
    zoran81 , Jul 31, 2017 :
    At first I install beta with just cache wiping from recovery and I faced some more battery draining..and few days ago I perform a full wipe and now I'm waiting to see if I got any improvements..time will tell
    Sun90, xcrm and Bobbie63 like this.
  8. zoran81
    Because he is some lazy *** :D
    Android450, HarryRag, adpro and 5 others like this.
  9. 9993572434
    Eclair Jul 31, 2017
  10. varma246
    varma246 , Jul 31, 2017 :
    Use Nova launcher
    Or
    Wait for Android O.
  11. CraigMcK27
    Eclair Jul 31, 2017
    CraigMcK27 , Jul 31, 2017 :
    I don't have much success with Nova and outlook mail notifications, it's fine on others but seems to ignore outlook. Yes it is switched to include outlook.
  12. G_Julio_Mendoza_SLaf
    Ice Cream Sandwich Jul 31, 2017
    G_Julio_Mendoza_SLaf , Jul 31, 2017 :
    Since you can't tell that you are using the stable build and posting on the beta thread, you really shouldn't worry too much about the security patch.
  13. cpvijay
  14. John Mofet
    John Mofet , Jul 31, 2017 :
    After updating open beta 20/11 for my oneplus3 I'm facing emergency call issue (SOS) and automatically mobile gets restarted. Please advice how to fix this.
  15. G_EVR
    Honeycomb Jul 31, 2017
    G_EVR , Jul 31, 2017 :
    Is there a way of disabling the annoying "High power usage app draining battery" notification?
  16. ck_______k
    Cupcake Aug 1, 2017
  17. charanteja76
    Cupcake Aug 1, 2017
  18. varma246
    Lollipop Aug 1, 2017
    varma246 , Aug 1, 2017 :
    It's in your hands,if you want to switch read first post.
    Simple answer is No.
    xcrm, Sun90, zoestar and 1 other person like this.
  19. charanteja76
    Cupcake Aug 1, 2017
    charanteja76 , Aug 1, 2017 :
    I want the version as one plus 5 like slide up to open menu how it's possible plz help Mee???
  20. adpro
    KitKat Aug 1, 2017
    adpro , Aug 1, 2017 :
    Really?
    So, we have some OP5 features as well:D
    Sun90 and zoestar like this.
