90
OxygenOS Open Beta 20 for the OnePlus 6 and Open Beta 12 for OnePlus 6T
  1. G_Rohit_Arde_cWEK Cupcake Jun 17, 2019
    G_Rohit_Arde_cWEK, Jun 17, 2019 :
    Hi Everyone
    appreciate the efforts put in creating this. but there is lot of lag and launcher issues. Multiple day to day apps do not function. Need to rollback. request to let me know how to do that. I have downloaded the roll back file but I cannot install it.
  2. manasarora98 Honeycomb Jun 17, 2019
  3. gbelogarenko Eclair Jun 17, 2019
    gbelogarenko, Jun 17, 2019 :
    It was updated from 11 to 12 through TvRP, cleared the partitions, the installer of the firmware TvRP Madzhiks flashed the firmware and now the file system is not available in the rulebook, who did it have?
  4. dinbandhukumar Gingerbread Jun 17, 2019
    dinbandhukumar, Jun 17, 2019 :
    digital wellbeing, a great app for me and in my daily life ..helps me alot like I can reduce my spends time on social things and I can spend more time with family and personal works. Zen mode it really helps to where we can reduce the phone usage. thanks to the OnePlus team [e]1f60a[/e][e]1f60a[/e][e]1f60d[/e][e]1f60d[/e]
  5. E1551192368433 Cupcake Jun 17, 2019
  6. G_Rhydian_T-Jones_ibaw Honeycomb Jun 17, 2019
    G_Rhydian_T-Jones_ibaw, Jun 17, 2019 :
    Care to elaborate on your rather vague statement? If you have actual realistic ideas about HOW the camera could be improved, and what in your opinion needs to be worked on, then you should give OnePlus your feedback in the provided link.
    ironass likes this.
  7. chazey2 Ice Cream Sandwich Jun 17, 2019
    chazey2, Jun 17, 2019 :
    What you don't know where the off button is? If like me using for business use you'll soon learn leave the bloody thing at home when out with family for a bit of peace.
  8. F1541913158406 Cupcake Jun 17, 2019
    F1541913158406, Jun 17, 2019 :
    hello guys
    after updating software of my one plus 6 t the volte feature has been disabled. kindly suggest me about to enable this feature.
    Vikashlb likes this.
  9. G_Rhydian_T-Jones_ibaw Honeycomb Jun 17, 2019
    Have you checked that it is enabled under sim settings?
    ironass likes this.
  10. edy90s Honeycomb Jun 17, 2019
    edy90s, Jun 17, 2019 :
    anyone can confirm hotspot works properly? on stable I have random disconnects doesn't matter on Wich one 2.4 or 5.0 ghz. it's this latest beta like stable one?
  11. dermot33 Ice Cream Sandwich Jun 17, 2019
    dermot33, Jun 17, 2019 :
    Zen mode has helped me,did have a problem with using my phone at night and getting stuck looking at it while I should be asleep,now getting into the habit of switching on Zen mode so I know I can't use it and back to sleep
  12. Tumio Froyo Jun 17, 2019
  13. G_Rhydian_T-Jones_ibaw Honeycomb Jun 17, 2019
    edy90s
    anyone can confirm hotspot works properly? on stable I have random disconnects doesn't matter on Wich one 2.4 or 5.0 ghz. it's this latest beta like stable one?​
    I don't use hotspot all that often, but I've just tried mine on both 2.4 and 5 and seem to be working fine.
    edy90s likes this.
  14. edy90s Honeycomb Jun 17, 2019
    I found where is the problem. I have all the time bt on for (smartwatch, mi band, bullets and for car). Seems when the bt is on the hotspot doesn't works proper. I just turn off the bt by mistake and I see my laptops connects to the hotspot without any issue. When I start the bt again start crashing.
  15. J1550092704643 Froyo Jun 17, 2019
    J1550092704643, Jun 17, 2019 :
    Another bogus bs update.
    Wheres the improvements to the camera?
    Why does it take so long to test security patches?
    Typical OP BS
    kshgarg likes this.
  16. J1550092704643 Froyo Jun 17, 2019
    Since you wanna be a wise ***, this may help break it down, it's a piece of sh*t.
  17. Akshay Mittapalli Cupcake Jun 18, 2019
  18. F1541913158406 Cupcake Jun 18, 2019
    F1541913158406, Jun 18, 2019 :
    yes I have checked
  19. aatishsaraf Cupcake Jun 18, 2019
    aatishsaraf, Jun 18, 2019 :
    I have been facing battery draining problem as well post current beta update. Tried below steps :
    1. Tried rebooting - Did not help
    2. Cleared cache - Did not help
    3. Observed which app was draining the battery. For me it was Work profile - Gmail App. Disabled it for a couple of days, and suddenly battery life went up by ~50% (from 15-16 hrs to upwards of ~25 - 26 hrs)
    ironass likes this.
  20. F_Jonathan_Valverde_pSSd Cupcake Jun 18, 2019
