90
OxygenOS Open Beta 20 for the OnePlus 6 and Open Beta 12 for OnePlus 6T
  1. edy90s Honeycomb Jun 18, 2019
    edy90s, Jun 18, 2019 :
    if you have bt on , turn it off and try again, seems for me after turn off bt works
  2. DundarKadanali Cupcake Jun 18, 2019
  3. ironass KitKat Jun 18, 2019
    ironass, Jun 18, 2019 :
    Some quick questions...
    1. Which country and carrier are you on?
    2. Go to your dial pad and enter... *#*#4636#*#* . Phone information > "Set preferred network type"... post what it states there.
  4. DundarKadanali Cupcake Jun 18, 2019
    DundarKadanali, Jun 18, 2019 :
    1. country - turkey
    carrier - Vodafone
    2- when I enter *#*#4646#*#* , no action. only a white blank with dial page.
    thks
  5. ironass KitKat Jun 18, 2019
    Strange, it should take you straight to the, "Testing", page once you have entered those characters into your dialer.
  6. DundarKadanali Cupcake Jun 18, 2019
    I tried several times..but not working..
    any other method?
    thkns
  7. ironass KitKat Jun 18, 2019
    Not really. Try... Settings > System > Reset options > Reset Wi-Fi, mobile & Bluetooth.
    This will reset the above options and update your carrier's APN settings.
  8. Chinaroad Gingerbread Jun 18, 2019
    Chinaroad, Jun 18, 2019 :
    don't dial on truecaller for exemple, dial on the defaut app and it's *#*#4636#*#*
  9. leoflorov Cupcake Jun 18, 2019
    leoflorov, Jun 18, 2019 :
    When you just uninstall apk Digital Wellbeing from your phone by the rumors of slowing down the system.
    ironass likes this.
  10. srikanth.s Honeycomb Jun 18, 2019
    srikanth.s, Jun 18, 2019 :
    Tumio
    From apk mirror which version of google play service download?​
    Any specific reason for update ?
    I dont recommend update to system apps using apks. I once faced system bootloop soon after install of system apk related to location. I had to reset phone to fix.
  11. Naughty_Potato Gingerbread Jun 18, 2019
  12. Nishad sk Donut Jun 18, 2019
  13. abmessi10 Cupcake Jun 18, 2019
    abmessi10, Jun 18, 2019 :
    I can't change the audio tuner settings when i connect earphone. Its happening from the open beta 11 update.
  14. Tumio Froyo Jun 18, 2019
    Tumio, Jun 18, 2019 :
    G. Play Service use a lot of battery so I update for maybe more performance.
    Usually update this and the One Plus Camera, no more. (my actually version is 3.3.10)
  15. srikanth.s Honeycomb Jun 18, 2019
    Yes..I also have that issue with GP. Let me know if u managed to install and see improvement in battery usage.
  16. dinbandhukumar Gingerbread Jun 18, 2019
  17. ngydat KitKat Jun 18, 2019
    ngydat, Jun 18, 2019 :
    In the settings of the app ? (just a guess)
  18. dinbandhukumar Gingerbread Jun 18, 2019
    dinbandhukumar, Jun 18, 2019 :
    I checked there is no option actually..
  19. ngydat KitKat Jun 18, 2019
  20. Maazperwez Gingerbread Jun 18, 2019
    Maazperwez, Jun 18, 2019 :
    i am using swift theme i have everything dark including whatsapp instagram Twitter etc..
