91
OxygenOS Open Beta 20 for the OnePlus 6 and Open Beta 12 for OnePlus 6T
  1. j0k3rip
    Gingerbread Jun 14, 2019
    j0k3rip , Jun 14, 2019 :
    I have been using Beta 20 on OP6 for the past two days. In previous Beta 19, I got 6hrs+ SOT but now I roughly got 4hrs - 5hrs SOT with the digital wellbeing turn on. I was wondering if anyone have the same issue as mine.
    #61
    ledsled, vjayy7684 and iamkrafi like this.
  2. B_Wrath
    Nougat Jun 14, 2019
    B_Wrath , Jun 14, 2019 :
    I can positively say, he is wrong. You'll get it on June 31.
    #62
    Vikashlb likes this.
  3. macsaikrishna
    Donut Jun 14, 2019
    macsaikrishna , Jun 14, 2019 :
    Post open beta 20 update my alert slider does not recognise or activate the silent mode. tried the basics like restart. no improvement. please assist.
    #63
  4. B_Wrath
    Nougat Jun 14, 2019
    Clear the dirt in the side of your slider.
    #64
    drl431 and Deactivated User like this.
  5. T1546786792579
    Cupcake Jun 14, 2019
    T1546786792579 , Jun 14, 2019 :
    It would be great if there was a way to show you had a new notification if the phone is screen down. Maybe the camera flash could light up for like a second or so. I realise this is probably not possible but it would be useful if something like this could be done.
    #65
  6. bigalcy
    #66
  7. lolygang
    lolygang , Jun 14, 2019 :
    click the pen on your notification panel and then drag in the screen recorder
    #67
  8. macsaikrishna
    Donut Jun 14, 2019
    It's physical action is as smooth as it should be. checked for any visible blocks in the slider. nothing's blocking it. it slides up but the phone does not show nor activates the silent mode.
    #68
  9. B_Wrath
    Nougat Jun 14, 2019
    There are apps for that.
    #69
  10. B_Wrath
    Nougat Jun 14, 2019
    Use a very thin plastic tool and try to clean it. It has worked for every complaint of slider not working.
    #70
    Starcommander likes this.
  11. macsaikrishna
    Donut Jun 14, 2019
    Okay Warth. will keep you posted post following your instructions.
    #71
    B_Wrath likes this.
  12. Ryanf78
    Ryanf78 , Jun 14, 2019 :
    screen record is in the drop down menu. hit the pencil icon and add it the other icons you have already selected to be on the quick toggles settings.. good luck. it's hidden by default. you must enable it.
    #72
  13. macsaikrishna
    Donut Jun 14, 2019
    Awesome, It worked. cleaned it with a brust and it does work as normal. Thanks bro.
    #73
    B_Wrath likes this.
  14. Deactivated User
    Jun 14, 2019
    #74
    ledsled and B_Wrath like this.
  15. macsaikrishna
    Donut Jun 14, 2019
    #75
    Deactivated User likes this.
  16. B_Wrath
    Nougat Jun 14, 2019
    Always works. Happy to help :)
    #76
    keithnyc likes this.
  17. Iamrohit.07
    Honeycomb Jun 14, 2019
    #77
  18. B_Wrath
    Nougat Jun 14, 2019
    #78
  19. Iamrohit.07
    Iamrohit.07 , Jun 14, 2019 :
    I put many question marks. i think you didn't saw.
    #79
  20. Iamrohit.07
    And my expectations are not based on anyone's promise. I am asking about whether it will be added in future or not?
    #80
