268
OxygenOS Open Beta 21 for the OnePlus 5 and Open Beta 19 for OnePlus 5T
Thread Status:
Not open for further replies.
  1. rchile
    Eclair Nov 29, 2018
    rchile , Nov 29, 2018 :
    yes if you are eager to try then do it all data is saved as it is else wait for oxygen os
  2. Martin Bonnet
    Gingerbread Nov 29, 2018
    Martin Bonnet , Nov 29, 2018 :
    It depends on the fact you do it properly or not. Even if you wipe all your datas, there's a slight risk that's taken for no reason cuz pie will be out pretty soon
  3. rchile
    Eclair Nov 29, 2018
    no id don't find them i think full screen gestures are specific to 5t only.
    Mri2907 and I1539982403974 like this.
  4. Chuck_James
    Honeycomb Nov 29, 2018
    Chuck_James , Nov 29, 2018 :
    yes, it s real. Beta 22 is available on China version. we are still waiting for Oxigen OS :)
    I1539982403974 likes this.
  5. I1539982403974
    Eclair Nov 29, 2018
  6. Rajatkumar29
  7. rpotdukhe
    Froyo Nov 29, 2018
    rpotdukhe , Nov 29, 2018 :
    Martin Bonnet
    It depends on the fact you do it properly or not. Even if you wipe all your datas, there's a slight risk that's taken for no reason cuz pie will be out pretty soon​
    oh , you mean if someone does something wrong then only it will brick right ?
  8. rpotdukhe
    Froyo Nov 29, 2018
  9. Steals_xxx
    Cupcake Nov 29, 2018
    Steals_xxx , Nov 29, 2018 :
    change language on CN
    rpotdukhe likes this.
  10. Martin Bonnet
    Yep. And tbh I think it's really easy to brick this phone, I bricked mine like 2-3 times because of the encryption... Anyway that's up to you bro
  11. SoniaB
    Nougat Senior Moderator Nov 29, 2018
    SoniaB , Nov 29, 2018 :
    It does though. If you recall that when the OOS Beta Pie for OP6 was released and people moved to it, those that then wanted to go back to stable, had to flash a specific downgrade build to get back to Pie (noted in the Beta 1 thread).
    The leaked build is for H2OS Pie for OP5/5T. So anyone who flashes that may not be able to successfully downgrade back to OOS Stable. You may know the process involved but what if you need a specific downgrade build to flash in the first instance? Chances of bricking your device going to the last OOS stable from H2OS is possible. Yeah?
    Those that know what they are doing will be able to work it for sure, but still the risk is there. I merely pointed it out
  12. rpotdukhe
    Froyo Nov 29, 2018
    Martin Bonnet
    Yep. And tbh I think it's really easy to brick this phone, I bricked mine like 2-3 times because of the encryption... Anyway that's up to you bro​
    okay , but i am good this flashing stuff , so no worries.
    gotshoaib likes this.
  13. Mr_Cyrox
    KitKat Nov 29, 2018
    Mr_Cyrox , Nov 29, 2018 :
    Oh right...
    Completely forgot about it :)
    My bad :rolleyes:
    deviantartjr and SoniaB like this.
  14. fr3quency
    Froyo Nov 29, 2018
    fr3quency , Nov 29, 2018 :
    If you bricked it the first time, you would't be able to brick it a second or a third time... ITS BRICKED.
    deviantartjr and gotshoaib like this.
  15. Austin72
    Austin72 , Nov 29, 2018 :
    Unbrick a brick and you no longer have a brick
  16. Martin Bonnet
    Nope, there're some ways to recover from hard brick. You can use the phone's stock firmware :)
  17. paulomodesto
    Ice Cream Sandwich Nov 29, 2018
    paulomodesto , Nov 29, 2018 :
    At what time "chinese" used to be launched the betas?
    Assuming now it´s already Friday, 30 November on China and it´s 1:00 AM.
    In my country now it´s Thursday 29 November, 17:00 PM.
  18. deviantartjr
    lucifer3036 likes this.
  19. sonofagun
    sonofagun , Nov 29, 2018 :
    Seconded. Been there a couple of times myself.
    UmairBhayat and Martin Bonnet like this.
  20. Pawankumarvats
    Donut Nov 29, 2018
