268
OxygenOS Open Beta 21 for the OnePlus 5 and Open Beta 19 for OnePlus 5T
Thread Status:
Not open for further replies.
  1. aadis04
    Froyo Dec 4, 2018
    aadis04 , Dec 4, 2018 :
    have u reinstalled the play store??
  2. Rajesh Shiva
    Gingerbread Dec 4, 2018
    Rajesh Shiva , Dec 4, 2018 :
    Yes i uninstalled and reinstalled thats why it happened
  3. Icecreamypie
    Ice Cream Sandwich Dec 4, 2018
    Icecreamypie , Dec 4, 2018 :
    You forgot quinoa
  4. Martin Bonnet
  5. Owais167
    Cupcake Dec 4, 2018
    Owais167 , Dec 4, 2018 :
    maybe you unlocked your bootloader
  6. Rajesh Shiva
  7. Icecreamypie
    The day When all op5t users sold their phone
    MicBlang and deviantartjr like this.
  8. aadis04
    Froyo Dec 4, 2018
  9. sridiculous
    sridiculous , Dec 4, 2018 :
    For anyone that's curious to get on to HOS Pie, I tried that myself yesterday and came back to OOS without any loss of data. I will post my steps here for anyone that wants to give it a shot.
    I am on OB21, encrypted, rooted and using TWRP by Siankatabg with Pie decryption support.
    1. First remove any Security on the Phone (Swipe, PIN, Password nothing). Just choose None. You might lose some accounts that require a secure device, but easy to add them all back.
    2. Download the latest Pie HOS Beta and modify it by removing the Compatibility.zip from it's contents. I used my linux system to do this and moved the file to the phone internal storage. (Any Folder there is fine)
    2. Reboot to recovery.
    3. Backup -> Backup everything.
    4. Install -> Select the modified HOS Zip File.
    5. For being rooted -> Add Zip -> Magisk 17.3
    6. Install.
    7. Once successful, I prefer to wipe cache and dalvik just to be sure and then reboot.
    It will take a couple of minutes to fire up, but works just fine for most apps. Some apps might require the permissions to be set right, but should work fine.
    I wanted to try getting back to OOS, so I rebooted to recovery, wiped everything, Restored from the backup made earlier. Just this will cause bootloops. So, I had to install OOS OB21 and Magisk again and reboot works just fine, where there is no loss of data and everything the exact same way as I had it.
    Hope this helps someone that wants to give it a shot.
  10. Jovericain
    Jovericain , Dec 4, 2018 :
    except, battery life on Oreo is absolutely not mediocre. and I have absolutely no problem proving it. but I won't because everyone here is supposed to have the device as a daily driver! and if they want to fool themselves by making up some flaws about the current OS just to promote the next one, that's their problem! but they should not try to fool other people. I know the battery life can be improved anyway but it it will not create new hours of screen-on- time and the battery life is absolutely not a key feature that needs improvement on the OnePlus 5/5t!
  11. Rajesh Shiva
  12. Alex_Madalin
    Donut Dec 4, 2018
    Alex_Madalin , Dec 4, 2018 :
    Oneplus communication to community is 0 in this case for a company that says that they listen to it. I am a pacient guy, but this is already too much. OP5/t is the new OP2.
  13. aadis04
    Froyo Dec 4, 2018
  14. jays88
    jays88 , Dec 4, 2018 :
    yes, me too, they delete my post. Seems they don't want to listen some problem instead of 5th anni.
    MarkAle likes this.
  15. Rajesh Shiva
  16. aadis04
    Froyo Dec 4, 2018
  17. Rajesh Shiva
    Sure , Thank you
    aadis04 likes this.
  18. aadis04
    Froyo Dec 4, 2018
  19. Vladut123
    Honeycomb Dec 4, 2018
    Vladut123 , Dec 4, 2018 :
    oxygenos based on android pie beta for oneplus 5 will be available this week?
  20. G1543923987530
    Cupcake Dec 4, 2018
    Joey463 and gotshoaib like this.
