744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Dec 12, 2018
  2. Aziz_Amin_Oneplus
    Jelly Bean Dec 12, 2018
    Aziz_Amin_Oneplus , Dec 12, 2018 :
    Guys wanna check an Easter Gesture, just enable Navigation Gesture mode and open call dialer or any app on your home screen and then from down long swing from top of the screen the app will go like a football
  3. andreoski
    Froyo Dec 12, 2018
    andreoski , Dec 12, 2018 :
    and excitment gone :(
  4. G_Shahid_Ummer_dbrV
    Froyo Dec 12, 2018
    G_Shahid_Ummer_dbrV , Dec 12, 2018 :
    Juampii17
    i think you can't just flash it. if you wipe data, system and caches then flash ob19 and you'll be fine. Backup first with OnePlus switch and don't wipe internal storage. I think you have twrp?​
    No my phone isn't rooted. I do not have a custom recovery.
  5. superplus
    Head Moderator Head Moderator Dec 12, 2018
    superplus , Dec 12, 2018 :
    Welcome to the forums for both of you. Please have a look at the Terms & Rules.
    If you face any issues after installing an update, please post about them in the official announcement post that accompanies each OTA or follow the instructions in the first post to log a bug.
    Threads merged.
    Cheetosdust likes this.
  6. dego007
    Gingerbread Dec 12, 2018
    dego007 , Dec 12, 2018 :
    Is the issue with the mic not working affecting receiving calls as well ?
    Is the Playstore not being certified stopping us from downloading anything at all ?
    Please advise if these issues are dealbreaker.
    Just want to be sure that the beta is worthy of being used as a daily driver, as I am jumping from stable to beta for the first time.
  7. G_Antonio_Lopez_GljI
    Donut Dec 12, 2018
    Yag1z likes this.
  8. faqir.m.abdullah
    Froyo Dec 12, 2018
    faqir.m.abdullah , Dec 12, 2018 :
    Well I went from stable to beta for the first time and everything is working fine. I factory reset the phone before updating and did a backup of my data.
  9. G_Rohit_Sarna
    G_Rohit_Sarna , Dec 12, 2018 :
    done it now is verified but i still cant update apps it just says downloading n thats it !
  10. Jason Gill
    Eclair Dec 12, 2018
    Jason Gill , Dec 12, 2018 :
    https://www.apkmirror.com/apk/arnov...build-6-1-021-220943556-android-apk-download/
  11. deco1789
    Cupcake Dec 12, 2018
    deco1789 , Dec 12, 2018 :
    Installed via OTA and now settings keep crashing, I cant open 'App Info' because it crashes as well.
    Already wiped cache through recovery and nothing happens.
    any tips?
  12. dego007
    yes factory reset is the best option I know
    I want to save the hassle of doing a backup and reset, so asking if its daily driver material after a dirty flash
  13. N1517235739249
    Eclair Dec 12, 2018
    N1517235739249 , Dec 12, 2018 :
    two of the major bugs which I have noticed yet are
    1. Can't download anything from Play Store
    2. Microphone not working on 3rd party apps like PUBG
    Shashang and Jayprajapati2542 like this.
  14. F_Gurneet_Mehta_omsM
    kazecs likes this.
  15. KyloWhen
    Honeycomb Dec 12, 2018
    KyloWhen , Dec 12, 2018 :
    I've had no issues so far, I've dirty flashed over H2OS.
  16. dego007
    nice ! I am gonna take the leap as well then.
    Did you do a local upgrade to install ?
  17. MarkusD9
    MarkusD9 , Dec 12, 2018 :
    Hi guys. I downloaded beta for 5t from official site, moved ittointernal storage and when I choose the file to install it shows this. I am confused cause it said that this version is lower than the one I already have on my phone. Can someone explain to me what is happening?
  18. G_Shahid_Ummer_dbrV
    Froyo Dec 12, 2018
  19. CODEGEEK
    CODEGEEK , Dec 12, 2018 :
  20. KyloWhen
    No, I'm on TWRP, so I stuck to it. Hang on, I'll see if I can find the set of instructions I followed.
