744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. udayachendur Honeycomb Dec 12, 2018
    udayachendur, Dec 12, 2018 :
    Actually I prefer the new setup...
    It's neat and clean.
    Even now you have options under DND settings for having expections for selected contacts. Did you check that?
    ju57_74zz likes this.
  2. J1515669914702 Donut Dec 12, 2018
    J1515669914702, Dec 12, 2018 :
    Is there a way to change to volume slider position?
    Because I think the left side is a bit challenging to reach.
    Couldn't find anything in the settings.
  3. N1520605053962 Froyo Dec 12, 2018
  4. harshmehtaa Froyo Dec 12, 2018
    harshmehtaa, Dec 12, 2018 :
    Unable to update any app via playstore anyone facing same bug or any solution to the bug?
  5. Gladi77 Froyo Dec 12, 2018
    Gladi77, Dec 12, 2018 :
  6. J1515669914702 Donut Dec 12, 2018
    I had the same problem.
    I cleared the cache and after a quick restarted is the problem solved.
    It works for me and hopefully for you as well.
  7. Djordi63 Cupcake Dec 12, 2018
  8. J1515669914702 Donut Dec 12, 2018
    Please specify your question so that we're able to help you.
  9. anagua Cupcake Dec 12, 2018
    anagua, Dec 12, 2018 :
    I would like that notifications were dark when choosing dark theme!
    the_reckoner likes this.
  10. J1515669914702 Donut Dec 12, 2018
    Yeah that would be great
  11. spyridonas Froyo Dec 12, 2018
  12. Gladi77 Froyo Dec 12, 2018
    Bluetooth logo only shows when bluetooth device is connected. (that doen't count smartwatches)
    crzfyr, the_reckoner and udayachendur like this.
  13. udayachendur Honeycomb Dec 12, 2018
    Nope. It is actually placed where the volume buttons are.
  14. J1515669914702 Donut Dec 13, 2018
    J1515669914702, Dec 13, 2018 :
    That's a bit shitty because I'm holding my smartphone with the right hand.
    SurajLoharia likes this.
  15. Adthr33 Gingerbread Dec 13, 2018
    Adthr33, Dec 13, 2018 :
    anyone having issues downloading from the OnePlus site?
    mines stuck at 14% downloading
  16. udayachendur Honeycomb Dec 13, 2018
    udayachendur, Dec 13, 2018 :
    Even I handle it with right hand.
    But be honest, it's far better than it being on top.
  17. J1515669914702 Donut Dec 13, 2018
    That's right.
    It's just complaining at a high level.
    udayachendur likes this.
  18. harshmehtaa Froyo Dec 13, 2018
    harshmehtaa, Dec 13, 2018 :
    Didnt solve my problem.. Cleared data of package installer as well
  19. G_Taraun_Frontis_eEHv Cupcake Dec 13, 2018
    G_Taraun_Frontis_eEHv, Dec 13, 2018 :
    hi,
    after this update, I have not been able to keep a stable data connection. i grabbed the update via a Canadian vpn thru the playstore and after resetting all of my wifi, network, Bluetooth settings, and restarting my device, this exclamation point still comes on with no data connection.
    I'm on TMobile and I have the OP5T.
    any advice?
    rantlers62 likes this.
  20. rizwan.87 Cupcake Dec 13, 2018
    rizwan.87, Dec 13, 2018 :
    Does anyone have issues with connecting to Google (app updates from playstore are slower, new apps can't connect to Google account for sign in etc?)
