744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. W1544672805912
    Cupcake Dec 13, 2018
  2. Sai3034
    Eclair Dec 13, 2018
    Sai3034 , Dec 13, 2018 :
    I am also facing same issue
    N1513561618663 likes this.
  3. varun varna
    Jayprajapati2542 likes this.
  4. MindfreakBS
    Gingerbread Dec 13, 2018
  5. Harshag11
    Froyo Dec 13, 2018
    Harshag11 , Dec 13, 2018 :
    Those of you complaining about brightness, it is not an issue Google has changed the slider from linear to logarithmic. So 15% before its not really 15% in New slider.
    Copied from xda post on pie dp3
    The brightness slider behavior changed in this preview: It now changes the brightness logarithmically instead of linearly. Before this preview when it was linear, about 90% of the brightness was controlled by the lower 20% of the left of the slider, and the upper half of the brightness slider barely changed the perceived brightness. The old 50% brightness was almost identical to 100% max brightness, and the old 5% brightness was significantly brighter than 0% brightness. Now, the change in perceptual brightness is now more uniform as you increase or decrease the slider.
    The brightness slider position should spend most of its time throughout the day near-max now, but that's fine. The brightness of the panel hasn't changed, just the behavior of the brightness slider, and for the better. Other OEMs have had a logarithmic brightness slider since forever, Google just only now caught up with this standard physics-based implementation
    https://www.reddit.com/r/Android/comments/8p27iw/android_dp3_is_out_now/e084lyu/
    Hope this helps
  6. Jayprajapati2542
    Froyo Dec 13, 2018
  7. Jayprajapati2542
    Froyo Dec 13, 2018
    Jayprajapati2542 , Dec 13, 2018 :
    Restart the phone and check it
  8. MindfreakBS
    MindfreakBS , Dec 13, 2018 :
    Go to settings - apps & notifications - Google Play - Clear your Google Play app data and cache.
    Reboot your phone and let your Google Play app update automatically.
  9. G_Prince_Kumar_LUlp
    Donut Dec 13, 2018
  10. MJ_Vikram
    KitKat Dec 13, 2018
  11. Robert Uszok
    Froyo Dec 13, 2018
    Robert Uszok , Dec 13, 2018 :
    So... Old version of launcher - I guess it's something about 2.5.
    Go to settings -> apps -> all apps -> launcher OnePlus -> three dots at right top corner -> uninstall updates (it's free translation from polish so may be little different words). After that version of launcher goes up to 3.something. Then you have pill, and recent apps will be in horizontal version.
  12. G_Prince_Kumar_LUlp
    Donut Dec 13, 2018
    A1514553126457 likes this.
  13. aadis04
    Froyo Dec 13, 2018
    aadis04 , Dec 13, 2018 :
    thanks it worked :)
    Sourav Kumar Sahu likes this.
  14. aadis04
    Froyo Dec 13, 2018
    turn off the microphone permission in google app
    not only pubg, whatsapp duo etc have microphone problem if google is given microphone permission. so turn it off and all other apps works mic
  15. faizan_ahmad xyz
  16. Narendra BN
  17. F_Punit_Dagur_HMIc
    MindfreakBS likes this.
  18. Robert Uszok
    Froyo Dec 13, 2018
  19. R2P
    Eclair Dec 13, 2018
    B1528635709872 likes this.
  20. sapkotasriyas
