744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. sabir.sayed Honeycomb Dec 13, 2018
    sabir.sayed, Dec 13, 2018 :
    There is a problem with your video file (102.2.7)
  2. B_Wrath Marshmallow Dec 13, 2018
    B_Wrath, Dec 13, 2018 :
    Are you trying to view an already downloaded video or trying to stream? Did you check with other networks?
  3. rjagadishchowdar Cupcake Dec 13, 2018
  4. Romak_99 Eclair Dec 13, 2018
    Romak_99, Dec 13, 2018 :
    Can we get an option later on to move back the clock in the status bar to the extreme right. Since the OP 5T doesn't have a notch ...the clock on the left looks kinda odd. It would be great to have an option.
    P.S. : My personal preference...others may differ.
    ...and kudos to all you guys for providing the update. It looks and feels great. The new buttery smooth animations are very optimized and I notice no lag. Battery life may have improved slightly. The OnePlus optimized Pie is really smooth and fast. I am loving it!
    rjagadishchowdar likes this.
  5. Shubham Gujjar Honeycomb Dec 13, 2018
    Shubham Gujjar, Dec 13, 2018 :
    Same like Hydrogen Os with offical google services support.
  6. jamyee Cupcake Dec 13, 2018
    jamyee, Dec 13, 2018 :
    how to install it in OnePlus 5,I haven't received yet the update officially.
  7. rjagadishchowdar Cupcake Dec 13, 2018
  8. mail_skool Donut Dec 13, 2018
    mail_skool, Dec 13, 2018 :
    It's still in Open Beta. Stable version will be out a bit later.
  9. deep0611 Froyo Dec 13, 2018
  10. Jitesh Saitawadekar KitKat Dec 13, 2018
    Jitesh Saitawadekar, Dec 13, 2018 :
    No clock place can't be moved as it's specifically designed for notch which is not available on OP5T.
  11. arafatkhatri Eclair Dec 13, 2018
    arafatkhatri, Dec 13, 2018 :
    I am unable to download & install Digital Wellbeing app on my OnePlus 5T after Android Pie beta update. Anyone on forum did installation or faced any challenges? Please advise.
  12. v7pul Eclair Dec 13, 2018
    v7pul, Dec 13, 2018 :
    Update: Uninstalling and reinstalling Netflix solves the problem for me.
  13. Udayan Nayak Cupcake Dec 13, 2018
    Udayan Nayak, Dec 13, 2018 :
    I am on stable Oreo right now. I downloaded the beta package. But when doing the Local upgrade, it is showing this message. The beta is a higher version than stable, then why is it showing such a message? Is it normal and should I proceed with this?
  14. ggrassi79 Donut Dec 13, 2018
    ggrassi79, Dec 13, 2018 :
    Great update! Nicely done!
    Will you be adding "Android Pie Rotate" feature? That would be very useful and one of the main reasons I was waiting for Pie update.
    Thanks guys!
  15. AloneBoy Alamin Froyo Dec 13, 2018
  16. juanvf19 Donut Dec 13, 2018
    juanvf19, Dec 13, 2018 :
    Audio tuner isn't working, im using one plus bullets wireless
    please help!!!
  17. Rakesh_Kumar_T_ Jelly Bean Dec 13, 2018
    Rakesh_Kumar_T_, Dec 13, 2018 :
    It's already there , but can only be used if you turn on navigation bar , or swipe on home button gesture . This is not available with OnePlus gestures
  18. IsaacHung Honeycomb Dec 13, 2018
    IsaacHung, Dec 13, 2018 :
    do you mean when u turn off auto rotate, but tries to rotate, there will be a button at the nav bar which allows u to manually rotate the screen? if yes, this function is indeed included
  19. veda2810 Gingerbread Dec 13, 2018
    veda2810, Dec 13, 2018 :
    one more small bug found while clicking photo on the camera there are two clock noises instead of one
    it just ruins the experience of taking a photo....also it seems jittery and buggy ...
  20. IsaacHung Honeycomb Dec 13, 2018
    Yes it is normal. (btw the system update section is the safest way to update, but if u downloaded the file and flashed it through local upgrade, it is completely normal and feel free to proceed)
    Udayan Nayak likes this.
