744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. FF7CLOUDSNOBODY
    Honeycomb Dec 13, 2018
    FF7CLOUDSNOBODY , Dec 13, 2018 :
    So is it just me or is there a wide spread issue with the built in torch/flashlight not working from either a gesture or from quick settings
  2. sachinmeet
    Gingerbread Dec 13, 2018
  3. IsaacHung
    IsaacHung , Dec 13, 2018 :
    Fluid. But there's padding at the left and right of the status bar. Also many users are reporting that their device is not certified
  4. sachinmeet
    sachinmeet , Dec 13, 2018 :
    Try clearing data and cache for google pay
    Worked for me
  5. G_Viru
    Jelly Bean Dec 13, 2018
    G_Viru , Dec 13, 2018 :
    yes I noticed that is huge padding
    IsaacHung likes this.
  6. lucasrubeng@gmai
    Cupcake Dec 13, 2018
    lucasrubeng@gmai , Dec 13, 2018 :
    hi it's seems to be that the stock recovery is not being installed after updating that's was caused my previous problem managed to solved by wiping and installing open beta 19 again then flash the ROM through stock recovery and it worked now I'm using open beta 20 Android pie
  7. Deb99499
    Deb99499 , Dec 13, 2018 :
    OnePlus5 device is getting crashed when I play songs on wynk player (10 songs in BackGround). please look into this issue asap as this is effecting my device's motherboard.
  8. G_Viru
    gotshoaib likes this.
  9. G_Viru
    why?
    not for me
    did you reset
  10. SumitGhosh22
    Donut Dec 13, 2018
  11. YRJ
    The Lab - OnePlus 7T Reviewer; Community Hero 2020 Dec 13, 2018
    YRJ , Dec 13, 2018 :
    Yes I have. Issue is quite frequent!
  12. YRJ
    I have already, and developers will be looking at this thread and posting here is necessary!
    Hope that helps
  13. SumitGhosh22
    Donut Dec 13, 2018
  14. sanjeetgupta
  15. SumitGhosh22
    Donut Dec 13, 2018
    SumitGhosh22 , Dec 13, 2018 :
    yes it is, click button check for updates
  16. Ketan Meshram
    Ketan Meshram , Dec 13, 2018 :
    Hello Guys,
    Where is "Pinned Beta Thread" for oneplus 5 , what it is exactly ??
    I have updated 9.0 from the link but my Volte option has vanished !? from settings.
    Can anybody help me with this
    thanks in advance
    Ketan
  17. YRJ
    Which app data? :confused:
    This is face unlock issue
  18. IsaacHung
    ...yes this is official.go to the system update section and you can upgrade to Android 9 Pie
  19. SumitGhosh22
    Donut Dec 13, 2018
  20. F_Gavin_Balloo_hGOP
    Froyo Dec 13, 2018
