744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. A1513440258929
    Cupcake Dec 13, 2018
  2. MJ_Vikram
    KitKat Dec 13, 2018
    MJ_Vikram , Dec 13, 2018 :
    yes you need to
  3. shyam_prakash
    shyam_prakash , Dec 13, 2018 :
    am a op5 user. and after updating to 9 pie , i think my 2 nd sim cant make calls and send sms. theres no problem for receiving the same but outgoing is restricted. is that a bug or...?
  4. i.ranatunga
    Donut Dec 13, 2018
    i.ranatunga , Dec 13, 2018 :
    is Bullets Wireless working fine with the audio tuner in this beta? has the sound improved?
  5. Shreekar vaidya
  6. PokiX
    Jelly Bean Dec 13, 2018
    PokiX , Dec 13, 2018 :
    Search for compatibility.zip . You have to remove that file from the zip. If you have no way to do it someone posted a modified zip on xda.
  7. marvinvb
    marvinvb , Dec 13, 2018 :
    Had the same problem. Just try to re/install Google Assistant.
  8. Tick_tac
    Donut Dec 13, 2018
    Tick_tac , Dec 13, 2018 :
    Phone has started lagging. 1plus is following the same method as Samsung. It publicises that it provides software upgrade better than other companies but what it does is makes the phone slower so that people has to give 600 $ to oneplus each year sorry twice a year coz it launches T and phone each year. First of all it should concentrate on one phone each year like apple and Samsung so that people can keep their invested phone for longer period. INSPITE of 6gb of ram after opening 3 4 apps phone lags. How come 6gb was more than enough last year and 10 gb is trending this year. I have a pc in my home which has 1 gb ram and it works faster than oneplus
    gotshoaib likes this.
  9. Cervantes
    Lollipop Moderator Dec 13, 2018
    Cervantes , Dec 13, 2018 :
    Please read the first post
    The beta thread is a thread of questions
    use the topic search instead of opening a new thread
    Thread merged
  10. Lavish 4117
  11. F_Aaron_Thomson_
    F_Aaron_Thomson_ , Dec 13, 2018 :
    Anyone having an issue with microphones the mic isn't working in phone I use headset to talk and I have tried changing the headset but the issue still remains is there any fix please help..
  12. PokiX
    You will get OTA if you are already on Beta channel.
    Read first post please.
  13. Ajeant12
    Donut Dec 13, 2018
    Ajeant12 , Dec 13, 2018 :
    Using OnePlus 5T (rooted) on OB19. I got the new update for Android pie but whenever I try updating it just restarts my phone.
    Can I update using blu.spark, will I lose my apps & settings, not internal storage. I know it won't completely format my phone but I just wanna know if it would delete all my apps when I flash the Open Beta 20 zip file via blu.spark recovery
    Thanks In Advance
  14. Lavish 4117
    Lavish 4117 , Dec 13, 2018 :
    what is beta channel?
  15. PokiX
  16. E1514471932083
  17. Liehjan
    Lollipop Dec 13, 2018
    Liehjan , Dec 13, 2018 :
    Beta 20 is live for 5t, so if you are on beta just "check for updates" on your phone.
  18. veda2810
    Gingerbread Dec 13, 2018
    veda2810 , Dec 13, 2018 :
    is anyone facing this issue ?.
  19. E1514471932083
    E1514471932083 , Dec 13, 2018 :
    my device 5T ok
  20. jamyee
    jamyee , Dec 13, 2018 :
    I have downloaded this file for OnePlus 5 that is 1.86 gb how to install it ,please guide for Android pie,thanks.
