744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. nofoo
    Froyo Dec 13, 2018
    nofoo , Dec 13, 2018 :
    I've seen the hints that the alarm slider is now functioning in another way.
    Also i've seen a hint that dnd mode can now be set somewhere else. I think it pointed to the top bar. But i don't see that i can set dnd there.
    Where am I supposed to (quickly) switch my phone to dnd now?
  2. G_Ceri_Jones_yeyi
    Cupcake Dec 13, 2018
    G_Ceri_Jones_yeyi , Dec 13, 2018 :
    Did an OTA upgrade to Beta 22 yesterday, phone rebooted after installing upgrade, went to post screen, then rebooted and left me with a blank screen.
    Rebooting follows the same cycle, can access the bootloader screen (vol up) but not the recovery screen (vol down), so cant even clear the cache to see if that works.
  3. sandeepkhurana_316
    sandeepkhurana_316 , Dec 13, 2018 :
    After using pie beta for 1 day i am back on ob 19 oreo.. There are few issues due to which i am not able to use it as daily driver.. Mic is not working properly.. Google play is having issues downloading apps and takes a long long time to install/update apps. Gcam is not yet fully supported (which is ok since pie beta is just released), google assistant is not working properly.. I hope it will get fixed in upcoming builds but for now i will stick to ob19..
  4. sidpathak1547
    Donut Dec 13, 2018
    sidpathak1547 , Dec 13, 2018 :
    same here bro microphone is not working while playing pubg
  5. Juampii17
    Gingerbread Dec 13, 2018
    Juampii17 , Dec 13, 2018 :
    did you go to settings/battery/battery optimisation/3 dots upper right corner/ advanced optimisation and check if you have deep optimisation enable? Also in system and app management check if you have deep clear
  6. aryan_kh1
    Eclair Dec 13, 2018
    aryan_kh1 , Dec 13, 2018 :
    Why is there no pill gesture for op5??
    pill gesture and the OnePlus gesture are different
    And also they are provided by google the why cutting them??
  7. Juampii17
    I know. But why would you use screen buttons when you can have the full screen enabled
  8. sabir.sayed
    Honeycomb Dec 13, 2018
    sabir.sayed , Dec 13, 2018 :
    tried both. same result. Even my phone freeze and have to restart. Dam my subscription getting wasted. lol
  9. Icecreamypie
    Ice Cream Sandwich Dec 13, 2018
    N1520605053962 likes this.
  10. Pablo Durán
    Froyo Dec 13, 2018
    Pablo Durán , Dec 13, 2018 :
    well for the buttons it doesn't make much sense but for the gestures it could be useful
  11. G_TheUnite_Club_PwIC
  12. Juampii17
    could be yes. I tried gestures 2.0 when the h2os closes beta was there for download and it's not like "wow" you get bored having hardware buttons but if you have none, then it's a very useful way to navigate with your phone
  13. I1508012528933
  14. rickvdsommen
  15. PokiX
    Jelly Bean Dec 13, 2018
    PokiX , Dec 13, 2018 :
    Not a single app crash and can't comment on these apps as I don't use them.
    USB debugging works fine.
    G_TheUnite_Club_PwIC likes this.
  16. amitshrikulkarni
    Froyo Dec 13, 2018
    amitshrikulkarni , Dec 13, 2018 :
    Finally much stable beta update for OP5 after long wait. Battery life seems awesome as of now. After 25Hrs still at 18% with 5Hrs of SOT. UI feels smooth but not fast. Didn't experienced single freeze or crash after update. Overall pretty good build. Hope to get regular beta updates now.
    Jish98 likes this.
  17. Nimit Chopra 59
    Froyo Dec 13, 2018
  18. vinayind47
    Donut Dec 13, 2018
  19. Jish98
    Froyo Dec 13, 2018
    Jish98 , Dec 13, 2018 :
    Go to play store and uninstall Oneplus launcher and then again update launcher. It'll work. I too faced this same problem.
    prvntrpth likes this.
  20. varun varna
