744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. amitmathew
    Eclair Dec 14, 2018
  2. The_Unkown
    Jelly Bean Dec 14, 2018
    The_Unkown , Dec 14, 2018 :
    correction, you can flash open beta 20 for your device . but be sure u r on latest version of stable oxygen
    gaurav.jagtap likes this.
  3. Bharath_siddharth
    Donut Dec 14, 2018
    Bharath_siddharth , Dec 14, 2018 :
    Sorry bro. I too faced the same problem but after removing the account it worked good for me.
  4. The_Unkown
    that's the SBI issue . don't worry. try after sometime. nothing for bug to be reported.
  5. Tejas Shetye
    Cupcake Dec 14, 2018
    Tejas Shetye , Dec 14, 2018 :
    thanks for your support ..
  6. rjc335
    rjc335 , Dec 14, 2018 :
    Night Mode is not working properly and the phone gets hanged automatically it shows only blue light at the top and black screen.
    There is stability issues occuring after the update..
    Kindly Help us with that.
    Though the features are really nice and user friendly Just need stability support and few changes.
    Hope to see good response from your side soon.
  7. The_Unkown
    no data is deleted , the steps is simple .
    download the zip to your phone
    move it to parent hierarchy of the storage ( just one step up from download folder )
    then go to setting
    system update
    click on gear icon on top right corner
    install from local upgrade
    once it's done , clear cache from recovery option
    ( optional , if no issue )
  8. The_Unkown
    it's working for me , clear the cache from recovery
    before that check the intensity of night mode , after pie , the strength of night mode is decreased , you can increase it from the setting.
  9. manasarora98
    Honeycomb Dec 14, 2018
  10. G_Amit_Verma_uBgT
    Eclair Dec 14, 2018
    manasarora98 likes this.
  11. manasarora98
  12. G_Amit_Verma_uBgT
    Eclair Dec 14, 2018
    G_Amit_Verma_uBgT , Dec 14, 2018 :
    i have both the Apps installed on my phone but it's only showing option for Uber not for Ola
  13. F_Gavin_Balloo_hGOP
    Froyo Dec 14, 2018
  14. daster_x
    Gingerbread Dec 14, 2018
    daster_x , Dec 14, 2018 :
    if you want to report real issue, better do the feedback with details https://forums.oneplus.com/feedback/ or use Community app -> Profile -> feedback
    as about stability - it is Beta and it is the first Open Beta of the completely new OS. it is normal to have some stability issues.. but this doesn't prevent me to use it as a daily phone.
  15. daster_x
    instead of waiting, better get in... to do the Beta better, and by this to help them faster release the stable.
    yuva_cool likes this.
  16. suhaib kazi
    Eclair Dec 14, 2018
  17. cozgunay
    Donut Dec 14, 2018
  18. GodKingOfCanada
    GodKingOfCanada , Dec 14, 2018 :
    magisk vanced YouTube.
  19. mano0506
  20. Xetmes
    Froyo Dec 14, 2018
    Xetmes , Dec 14, 2018 :
    Read a bit, this is intended, will learn after some time, increase brightens manual, after some time OS will set it properly. On my side is bit better after two days.
    yuva_cool and mano0506 like this.
