744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. _hakuna_matata
    Donut Dec 14, 2018
    julodegracia likes this.
  2. Xetmes
    Gingerbread Dec 14, 2018
    Xetmes , Dec 14, 2018 :
    Yeas, I did have this problem few times, mostly after enter to "Smart lock" settings. But after clearing cache in revovery mode seems to be fine.
  3. aykut39
    Honeycomb Dec 14, 2018
    aykut39 , Dec 14, 2018 :
    i dont think the sot is measured correctly... it doesn't seem realistic...
  4. X1513120527688
    Froyo Dec 14, 2018
  5. Manideep nuguri
    Eclair Dec 14, 2018
    Manideep nuguri , Dec 14, 2018 :
    There is problem with mic after pie beta update for op5t.google assistant not activated by voice. When i try to reset its not catching my voice.Even wsap calls are disconnected sometimes while using headphones. Iam getting a message that problem with mic. Please fix the issue
  6. The_Unkown
    Jelly Bean Dec 14, 2018
    The_Unkown , Dec 14, 2018 :
    having feature like gesture control is always cool, but at the end of day keeping the software clean is better than cool.
    when you have button control , I thinks it's ok not to have pixel gesture control.
    but it's your choice to ask.
    For me all important features should be present in stock and that is why I love Oxygen OS . If "unwanted " feature will be added more it will affect the system performance at the end of the day.
    for device which doesn't have button control , the gesture is must. but still you can ask for feature to the team which I would not suggest.
  7. Manideep nuguri
    Eclair Dec 14, 2018
    Google lens selfie potrait present. Quality decreased
  8. The_Unkown
    Ohhhh that sad to hear ,
    Have you checked the mic permission in setting , please check if permission is granted properly to the system apps. If you see everything in setting are correct , please head over to https://forums.oneplus.com/feedback
    And submit a bug report.
  9. RazerEdge
    Eclair Dec 14, 2018
    RazerEdge , Dec 14, 2018 :
    I don't think it is unwanted. Like you said we like oxygen os because it is stock or close to it. My deal is it they have the on screen buttons already (which is still not required according to your argument since there are buttons already. But that's what makes oxygen os different..) why not add the pixel gestures.
  10. RickPrado
    Froyo Dec 14, 2018
    RickPrado , Dec 14, 2018 :
    Strange I'm seeing the amount of bugs people are having. I'm not facing any of the reported issues, that's because I don't use the packege installer? Or because I'm on op5? Dunno but I'm enjoying the experience so far
    doekus likes this.
  11. aykut39
    vibration and ring are almost the same thing.. they totally screwed the slider.. who are those thousands idiots want not to hear notification sound but bzz-bzzz..
    doekus and The_Unkown like this.
  12. The_Unkown
    have you got widevine L1 security update , back announced in April for OnePlus 5 users to get it installed on your device from service centre .
    if yes , try Netflix and tell me if you still not facing any bug .
    apart from that for me also things are better.
  13. The_Unkown
    because I think it will do the same functions as the button do and if you are an engineer trust me you will appreciate to remove anything which are " REDUNDANT " for clean user experience .
    But but but , it's all your choice.
  14. RazerEdge
    Eclair Dec 14, 2018
    I wouldn't consider it as "reduntant" i would see it more as a feature.
  15. The_Unkown
    As I said , you can always ask the team to add the feature.
  16. Dimarko
    Cupcake Dec 14, 2018
    Dimarko , Dec 14, 2018 :
    For a couple of days I have been actively testing beta 22 for 9.0. Again, Oneplus spoiled something inside the system. 80% of powerful games are very slow, before they simply flew and the processing of photos from the modified pixel camera was processed a couple of times longer than it was on custom 9.0. And the interface itself often pulls me about animations. I do not know what to do?
  17. manojyarashi
    Froyo Dec 14, 2018
    manojyarashi , Dec 14, 2018 :
    So these are my views about this pie update after using for more than 24 hrs.
    I was very exited and waiting for the update like all of you and to tell you guys frankly I'm very disappointed with this update...
    At first I updated through the OTA and when I started facing lot of problems then I tried clearing cache from recovery but still the problems didn't solve so I used the "Erase everything" option from recovery and set it up like a new phone
    the bugs are as under
    CONS
    1. Netflix app not working over WiFi(only works with 4g or LTE connection)
    2. The phone hangs a lot and have already restarted more than 10 times since update.
    3. Scrolling is very buggy in almost all apps like chrome, Facebook, Twitter etc
    4. Missed call notification was missing (but got solved after clean install)
    Pros
    1. Camera has improved since beta 21 especially night shots
    2. love the new pie interface.
    3. Love the new notifications interface.
    hopefully I would love to see a full baked pie rather than eating a half baked one..
    waiting eagerly for beta 23 with all the bugs squashed...
    Reverting to beta 21 till we get beta 23
    Cheers....
  18. Bowsek
    Bowsek , Dec 14, 2018 :
    The_Unkown
    apart from that for me also things are better.​
    wiping cache from recovery fixed my Netflix. Works as normal including picture in picture mode. I have experienced very few bugs so far and has been a joy to use
  19. The_Unkown
    can you confirm if you have L1 widevine security installed ?
  20. Bowsek
    how do I check?
