744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. caffreyneal
    Cupcake Dec 15, 2018
    caffreyneal , Dec 15, 2018 :
    I liked the OnePlus style of contact icons. The letters are too mainstream. Please bring back those.
  2. Rambo15
    Froyo Dec 15, 2018
    Rambo15 , Dec 15, 2018 :
    No I personally have no problems with me everything works and have also installed the G Cam
  3. RPisOP
    Froyo Dec 15, 2018
    RPisOP , Dec 15, 2018 :
    I Have too much data which I need to backup , I just updated it through the system update place
  4. A1512739230053
  5. T1513868922921
    T1513868922921 , Dec 15, 2018 :
    after updating OnePlus 5t to pie 9...my microphone was not working for what's up calls and while playing games...suggest me if there is any solution ...
  6. iamanand
    Froyo Dec 15, 2018
    iamanand , Dec 15, 2018 :
    disable google app and reset app preferences it worked for me, hope it will work for you let me know
  7. Arokz
    Froyo Dec 15, 2018
    Arokz , Dec 15, 2018 :
    hi anyone facing ok google detection problem. i couldnt train my voice model after pie update.
    pls help if anyone solved it.
  8. iamanand
    Froyo Dec 15, 2018
    yes, it's a bug
    Arokz likes this.
  9. Arokz
    Froyo Dec 15, 2018
    glad that am not the one facing it. but assistant works via headset, its that I couldn't train Ok google Voice model.
    iamanand likes this.
  10. rj@5628
  11. iamanand
    Froyo Dec 15, 2018
    check if your WhatsApp call is working or not while using headphones ?
  12. Ssathiyanarayanan
    Gingerbread Dec 15, 2018
    Ssathiyanarayanan , Dec 15, 2018 :
    In case there is too much data, kindly backup them and then go ahead with clearing the cache. If that doesn't work out then flash the ROM from recovery after wiping the device clean. Usually the cache wipe clears lot of issues.
    RPisOP likes this.
  13. Arokz
    Froyo Dec 15, 2018
    sure will do that.
  14. iamanand
    Froyo Dec 15, 2018
    it is not working for many beta users
  15. rahuljaiswal739
    Donut Dec 15, 2018
  16. Dhruvit Jain
    Honeycomb Dec 15, 2018
    Dhruvit Jain , Dec 15, 2018 :
    I feel you. I try so many custom roms and data backup is a hassle indeed. But a clean flash is always recommended when going from one android version to another. This isn't a common bug happening with everyone. Try clean flashing. Or else, clear cache and try, if you haven't already.
    RPisOP likes this.
  17. G1520516281210
  18. RPisOP
    Froyo Dec 15, 2018
    clear cache didn't work , guess I'll just go ahead and try to backup and clean flash , might as well just go ahead and root my phone too xD I was just waiting for a stable android pie rom
  19. Varun Chunduru
  20. iamanand
    Froyo Dec 15, 2018
