744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. Rakesh_Kumar_T
    Jelly Bean Dec 12, 2018
  2. Sibinkb
    Donut Dec 12, 2018
  3. Lokesh Devaraj
    Gingerbread Dec 12, 2018
  4. 05cse212
    Cupcake Dec 12, 2018
  5. SidSince_1995
    SidSince_1995 , Dec 12, 2018 :
    don't make assumptions
  6. OskarsBk
    Eclair Dec 12, 2018
    OskarsBk , Dec 12, 2018 :
    Yes
  7. lockmunk
    Donut Dec 12, 2018
    lockmunk , Dec 12, 2018 :
    Q. My Play Store is showing "uncertified" after i downgraded to stable, how can i solve it?
    A: Clear Google Play Services data and Play store data and Reboot. Let Play store update automatically and it should change the status to Certified.
    gotshoaib likes this.
  8. Aasim K
    Froyo Dec 12, 2018
  9. sheng0729
    Donut Dec 12, 2018
  10. Dextro_619
    Honeycomb Dec 12, 2018
  11. Nitin shokeen
    Eclair Dec 12, 2018
    Mithr likes this.
  12. Amaan28
    Amaan28 , Dec 12, 2018 :
    5T was launched after 5 months of OnePlus 5.....so we can expect the same for Pie
  13. ohhtthatguy
    Eclair Dec 12, 2018
    Amaan28, gotshoaib and Mri2907 like this.
  14. vinod210383
    Donut Dec 12, 2018
    vinod210383 , Dec 12, 2018 :
    Try, Oxygen Updator
    Lokesh Devaraj likes this.
  15. YRJ
    The Lab - OnePlus 7T Reviewer; Community Hero 2020 Dec 12, 2018
    YRJ , Dec 12, 2018 :
    hey @Manu J. thankfully the update arrived via OTA quite instantly, have installed it and so far so good! I'll keep posting if anything goes wrong here and through feedback.
    also,
    are you sure nothing has been done in the camera department?
    initial impressions are that the camera performs much better after the update and the oil painting effect seems to have vanished. your reply in this regard will be appreciated.
    much thanks!
    Yash [e]1f60a[/e]
    Pritam_Dhokale likes this.
  16. gagan_k_26
    Eclair Dec 12, 2018
  17. Manu MK
    Eclair Dec 12, 2018
  18. vinod210383
    Donut Dec 12, 2018
    Same issue as of first Pie upgrade on OP6, the brightness is low than Oreo.
    No night sight like OP6 (may be available in next beta)
    Potrait works awesome compare to Oreo
    Front and back camera works well
    Pop up notification are awesome
    Volume leveler moved to side is awesome
    All good ...
    Vibration not working in slider
  19. Manthan5
  20. dying_osiris
    dying_osiris , Dec 12, 2018 :
    automatic brightness is broken since this update. please fix it. and also can't find the option to clear cache in settings.
